Question about Samsung DV448AEE Electric Dryer
I need to see how the dryer belt on my samsung DV448 dryer is routed. It isn't broken, but it isn't taut as well.
  • 560 Answers
It sounds like you have a bad or broken belt tensioner. It is located in the bottom of the unit close to the motor . It is a spring loaded pully assembly which keeps the belt taught. The belt simply goes around the drum and the motor shaft and the belt tensioner pully.
Posted on Sep 17, 2010
Tip
Inglis Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
All models use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
on Mar 06, 2010 | Dryers
Electrolux mex731cfs4 change dryer belt
Unplug unit from the wall.
Slide the unit forward until back and side are accessible if necessary disconnect dryer duct and washer water lines).
Remove the vented plate on the back to access the motor and idler arm using a LARGE Phillips-head screwdriver.
remove broken belt.
Remove 10 of the 11 screws holding the top on (leave the center front one; undo the front corners last, taking care not to let the front panel slip forward - it supports the drum).
Open the dryer door and gently pull the front plate forward, supporting the drum from the inside with one hand so it doesn't fall
Work the belt around the drum and between the front of the drum and the front panel. Held it mostly taut around the drum to slide it back to the existing belt mark. Grooved rubber side of the belt goes on the inside.
Push the front panel back into position while seating the drum on it. Temporarily attached the top with two back and two front screws. (The front panel overlaps the top; the top goes over everything else.)
Route the drive belt left-to-right over the idler arm pulley, pushed the idler arm to the left, route the belt around the motor shaft and then up over the drum.
The idler arm should (a) press on the OUTSIDE of the belt, (b) take up all the slack in the belt, and (c) not touch the motor shaft (touching it is what causes the awful noise). The belt should contact the motor shaft past the two nut-like things on the shaft (not between them).
reverse the removal process making sure all is connected again and all screws are in place power unit to test
Jun 24, 2014 | Frigidaire Washing Machines
The belt has come off my dryer and I'm tryint to put it back on, how do I get a digram of what it looks like when the belt correctly back in place?
It is something that you can repair yourself
You probably have a tensioner that has broken.
I am sorry but I do not have the Samsung routing available to me.
Below is a chart of the most common routing of dryer belts.
The part that has failed on your unit is probably the idler pulley/brackett.
You should be able to repair it without having to remove the drum
http://www.applianceaid.com/images/belt-config.JPG
Apr 26, 2011 | Samsung DV218AEW Electric Dryer
Tip
Franklin Dryer Belt Diagrams and Replacement
Installation Tips: Ribs face toward drum
Tip
Magic Chef Dryer Belt Diagrams and Replacement
Dryer stopped heating dv448
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 06, 2010 | Samsung DV448AEE Electric Dryer
Tip
Maytag Dryer Belt Diagrams and Replacement
For all single belt models use this diagram:
Installation Tips: Flat side of belt against drum
Tip
Norge Dryer Belt Diagrams and Replacement
Tip
RCA Dryer Belt Diagrams and Replacement
Tip
Westinghouse Dryer Belt Diagrams and Replacement
For all Westinghouse models use this diagram:
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
Samsung DV448AEE Electric Dryer Logo
398 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
