Question about Omega Plumbing
We commenced using our Onga water pump some time ago after a long period of inactivity. It went very well at first providing good pressure to several outlets now however the pressure has gradually dropped.Is there anything we can do?
  • 395 Answers
It appears that the pump is not running at full capacity due to a restriction either in the inlet or outlet pipes. If there is a gauze filter in the inlet it may be clogged. Also check the non return valve on the inlet side to ensure it is moving freely and sealing properly as it could be worn and restricting the flow.
Posted on Sep 17, 2010
Onga JJ 600 household pump with pressure cylinder. Pump cuts out at pressure but won't cut in until water flow has stopped. Pump approx 5 yrs old and no previous problems.
It sounds like a pressure switch problem. Check that your tank pressure is at two psi below your cut-in pressure. If it is correct, then I suggest replacing the press switch.
Jan 15, 2017 | Plumbing
Im on tank water using a onga pump, loss of water pressure at taps,how do i get it back tanks full, whole system is only 6mths old,thanks
check for a blockage at the pump inlet or outlet from the tank
(leaves, animal etc)
check that the motor is running at full rpms ( problem start/run capacitor--no guaranteed life of capacitor)
check for water leak after pump
Mar 31, 2016 | Plumbing
No pressure for onga pump
check for water supply to the pump
If it is a bore pump then check for enough water in the bore, injection pressure to lift the water. It may be necessary to control the output from the pump to maintain the injection pressure. ( put a tap on the outlet side and turn partially off)
check for sucking air at pipe fittings
Mar 08, 2015 | Cars & Trucks
My electric onga water pump which pumps water from my watertank to the house will not turn off. I have looked for a leak but cannot find one.
What is the model of the pump? What type of control does it have - pressure switch, electronic controller or what?
Jul 30, 2011 | Computers & Internet
Have an Onga JJ400 jet water pump several years old, pump is working but delivering poor water flow
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Jun 29, 2011 | Plumbing
The lifters colapse when the engine is shut off for a period of time and they take several mins. of running to pump back up. This engine has 117000 miles on it but it has had EXCELENT maintenance. It is...
it sounds like your oil pump is not working good. check oil pressure at cold and what weight oil are you using. it may be too heavy for it to get up to the top of the motor quick.if there was any build up in the head when you changed the lifters you may want to flush the oil system good then put fresh oil back in
Dec 16, 2010 | Ford Freestar Cars & Trucks
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
How do i prime an onga pump from repressuring to primiing
Open the priming port at the discharge pipe. Close the discharge valve and fill the priming port with water until it is full. Power up and switch on the pump. While running, slowly open the discharge valve until the water
pressure gage at the pump is 20 psi. That will be the running pressure of the pump, and the maximum opening of the discharge valve.
Sep 27, 2009 | Plumbing
Plumbing Logo
200 people viewed this question
Top Omega Plumbing Experts
Paul Carew
Tom Chichester
Are you an Omega Plumbing Expert? Answer questions, earn points and help others
