Hi I got a Peavey TNT 160 Bass Amp\r\nI need these parts please can you help me out...? or some thing to match them as they are hard to find maybe a dater chart on the Transtors for compatibility this all I can fined and it dos,nt give me enough information Transtors I need two 70474140...... W9150 two 70484140.......W9144 Resistors I need two CP-5-25 DALE 5W 5.6 ohms 10% C9146 two C9-5-32 DALE 5W 2K 10% C9139
  • 2 more comments
  • Rommel Cana
    Rommel Cana Sep 17, 2010
    can just post what is printed on the transistor ? or what is printed on the board?
    like Q6, RX , , is it on the main amp or preamp? These amp can work even without
    the power transistors connected ( in pairs ) only for troubleshooting
  • Julian Brown
    Julian Brown Sep 17, 2010
    This is what is printed on the transtors thats why i am haveing trouble
    They are the main power transtors
  • Julian Brown
    SJ-8227* 74140 MJ-15053 70474140 PNP 140V OUTPUT
    60142* 84140 2N3772 70484140 NPN 140V OUTPUT
  • Julian Brown
    Julian Brown Sep 19, 2010
    PEAVEY-tnt 160 bass amp Schematic Diagrams if eney one can find one pleace help
  • 6 Answers
SOURCE: bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Posted on Nov 08, 2007
Grubhead
  • 5056 Answers
SOURCE: Peavey TNT 160 has no response from both inputs, only preamp in
In my experience fuses rarely blow due to age! I suspect that whatever the guy said the problem was it was really a faulty transistors or IC in the power amp board.
You can check transistors with an Ohm meter in circuit to some extent. (the ones with a scale and needle are best for this) Look for a short between the terminals of each power transistor on the heat sink first. If any transistor sends the meter full across (both ways) you have found the fault.
Posted on May 27, 2009
  • 4234 Answers
SOURCE: Peavey 400BH
Thanks for the update. I'll need to look through my records for similar problems. Stay tuned...
Dan
Posted on Jun 13, 2008
VOTIT
  • 2071 Answers
SOURCE: Peavey TNT115 AMP cuts out
The problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating and shuts out the amplifier caused by abnormal distribution of current,try to check all the capacitor and resistor and replaced the defected parts ,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
konzzz
  • 255 Answers
SOURCE: No volume control
lower the volume of the cd player
Posted on May 08, 2009
Amp blow fuses immediately when power is switched on
There could be so many things wrong with it, but personally I find the most likely problem is the power supply.
Mar 15, 2015 | Peavey TNT 115 1x15"" 600W Bass Combo...
Volume control is scratchy
needs to be replaced....is this under warranty?
Apr 04, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Peavey 115s bass amplifier
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Peavey tnt 115 schematics
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Feb 26, 2012 | Peavey Electronics Peavey Tour Tnt 115...
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
Muffled Pulsing sound comng from my peavey TNT Bass amp?? help!
Funny how most problems I hear about amps and such happen to be from a Peavey product. I am a sound engineer and I wouldn't use peavey for a paper weight! Try trading it in for a better product.
Mar 16, 2010 | Audio Players & Recorders
753 people viewed this question
 Grubhead
Grubhead
