Question about Microwave Ovens
How do I install a replacement Cuisinart Motor Shaft Sleeve/Sheath for my DLC-7?
  • 857 Answers
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base - if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor - slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle - slide the lid counterclockwise until it won't slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
Posted on Sep 17, 2010
I have a Cuisinart cmw-100 microwave everything works except for the turntable. any suggestions?
Order a new turntable motor. Turn the microwave upside down and you can see the little door in the center where you can install it. Pretty easy, really.
Apr 18, 2017 | Cuisinart Microwave Ovens
New cuisinart microwave oven has jerky turntable
The glass plate may be incorrectly installed.
Mar 15, 2017 | Cuisinart Microwave Ovens
How do i replace lightbulb
The wraparound cabinet has to be removed to gain access.
Jun 10, 2014 | Cuisinart CMW-100 Microwave Oven
Why won't the microwave turntable won't turn?
This problem is very common.
The turntable motor is defect or its gear mechanism worn out.
You'll need to have the turntable motor unit replaced.
May 11, 2014 | Cuisinart CMW-200 Convection/Microwave...
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
Turntable not working
The actual m# is JNM1851SMSS 01.
The problem most likely is with the turntable motor or coupler. The coupler is the part that the glass plate sits on that is driven by the motor. You will need to gently pry the coupler off and see if it is damaged. To test the motor, find a straw or something hollow that will fit snugly over the motor shaft. Turn on the unit to see if it spins. If it doesn't, then the motor needs to be replaced. You can get it at Sears Parts or other appliance parts websites. To replace the motor, make sure the unit is unplugged before you begin. Remove the bottom base where the motor is located. Remove the motor and install the new one. Re-install the base. Install the coupler on the motor shaft and you should be good to go.It is rare that the controller which turns on the motor goes bad, but it is a possibility. If you feel uncomfortable performing the above instructions, you should call an appliance tech.
I have attached a picture of the coupler as well as a link to your model. The #42 on the drawing is the motor.
Good luck
Don't forget to vote and please leave any comments you wish
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JNM1851SMSS01/0432/0123370/G1010188/00001?blt=06&prst=&shdMod=
Dec 20, 2010 | GE JNM1851SMSS Convection/Microwave Oven
Cuisinart Microwave oven, 1000 watts
hello. sorry to hear of your problem.
here is the direct link to customer service at cuisinart. If anyone can help u, they can
http://www.cuisinart.com/support.html
let me know how u make out.
May 28, 2009 | Microwave Ovens
Need to plastic coupler that holds turn table in place
If you need a replacement turntable coupler, you can find this part listed as item number 942560 at repairclinic.com. Just type in your model number.
To replace, all you need to do is carefully slide something under the existing coupler (if you can) and pry up. The coupler will pull off the motor shaft.
If you cannot access the coupler due to the way it was broken, simply remove the bottom panel UNDER the oven. With the panel removed, locate the small turntable motor and loosen the mounting screws to remove. The coupler should be easily accessible with the motor out of the unit. Make sure you reinstall the turntable motor and bottom panel BEFORE you try to install the new coupler. The coupler needs to be installed from inside the oven cavity by placing it in the opening in the oven floor and pushing straight down onto the motor shaft.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 14, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
