Question about HTC Cell Phones
All sounds including speaker just quit working on my HTC hero. I checked for updates and settings but the settings are correct. Please help.
Unmount SD card
Format your SD card using the phone SD card
Posted on Sep 18, 2010
My friend wanted me to take a look at his HTC Hero S because he can't get the wi-fi to work. I go to looking at it and the Wi-Fi is turning itself on saying unable to scan for networks and then it tur
look for updates for your OS, its possible that there has been an update for his OS, also make sure that you run STOCK OS on your phone AT ALL TIMES. other OSes will simply cause your phone not to work at its full capacity or use the wrong settings on your phone's features, including wifi.
I hope this helped you!
Jan 29, 2014 | HTC G1 Smartphone
Tip
Battery Tips for the Sprint HTC Hero.....
Battery life on cells phone, especially the hoard of smart phones coming out, can be very short, especially right out of the box. The following are some tips to extend the time between chargings for the Sprint HTC Hero (and probably the European Hero as well as the Verizon Eris).
• update your system software to version 1.56. To check which version you have, go to Settings > About phone > scroll to see software version. To update, go to Systems updates from the same menu, and select Firmware update.
• turn the brightness down of your screen. The brighter the screen, the more juice you use from the battery. Go to Settings > Sound and Display > Brightness.
• turn off bluetooth, wifi, GPS, and mobile web when not in use. I place these widgets on one of my screens to have easy on/off access. Go to (+) > HTC Widget > Settings. I turn off everything at night, turn on mobile web during the day, and turn on the others as I need them.
• turn off the "Always On Mobile Network" setting. Go to Settings > Wireless Controls > Mobile network settings > Enable always-on.
• limit the amount of push to sync email and other applications.
• turn of the automatic updates for apps like Weather, Facebook, Twitter, email. With the apps constantly checking and pulling data, the battery will drain much quicker.
I can usually go about two days between chargings with moderate use and three days with light use.
Good luck.
on Dec 09, 2009 | HTC Hero Smartphone
How do you get the upgrade the htc hero to 2.1
Getting Started
Before you run the ROM Update Utility (RUU), make sure you have done the following:
  • Backed up the data on your device.
  • Standby or hibernation mode of your PC has been disabled.
  • Close all running applications on the PC.
  • Set aside approximately 25 minutes to allow the device to update.
  • Charged the battery to at least 30%.
  1. Download HTC Sync for Android.
    Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
    HTC Sync for Android 2.0.40 (39MB)
  2. Download the Hero 2.1 MR Upgrade executable file.
    Hero 2.1 Upgrade (113MB)
  3. Connect your HTC Hero to your PC.
    Use the supplied USB cable.
    If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
  4. Run the Hero 2.1 MR Upgrade RUU file.
    Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Mar 09, 2011 | HTC Hero Smartphone
How do I upgrade my operating system android hero
This website has a guide for rooting and upgrading the android version on the HTC Hero http://www.roothtchero.co.uk/
Feb 26, 2011 | HTC Hero Smartphone
My HTC hero will not allow me to delete text messages which is taking up all my memoery
My Hero used to take ages to delete messages and often used to freeze when it was doing it. However now my phone is running 2.1 update it deletes perfectly fine. Check if your phone is on 2.1 update, go to settings, about phone, software informations and it is the firmware version your looking at. If your phone is running lower then 2.1 update then go to settings, system software updates and press check now. If it says there is an update available then download it. Overwise you will have to download an app. The app i suggest is called 1-click cleaner, it allows you to quickly delete all the messages on your phone from the app. Hope this is of help to you.
Dec 19, 2010 | HTC Hero Smartphone
The speaker stopped working on my htc Hero all of the sudden. I cannot hear ringers or media at all - it acts as if it's constantly in vibrate mode.
Your Speaker is burnt out just found that out with mine today. Took it to Sprint store Tech & they replaced it with a brand new speaker free of chg because I have insurance otherwise you'll be charged about $40
HTC Hero
SPRINT
May 20, 2010 | HTC Hero Smartphone
Hi I have a Htc Hero and i cant for the life of me work out how to use the Bluetooth i have switched it on and tried searching the phone it comes up and pairs but does not connect ? Thanks
Right now i think you have to wait to for your carrier to release an update to make the bluetooth work correctly.
I checked into it already and i haven't seen a scheduled release date for the update
Feb 16, 2010 | HTC Hero Smartphone
I want Modem Driver for HTC Hero phone using sprint network
Using the HTC Hero as a USB Modem
In order to use this functionality, the HTC Sync software must be installed onto the PC first (http://blog.brightpointuk.co.uk/synchronise-htc-hero-microsoft-outlook).
The HTC Sync installer is included on the SD card that comes in the Hero sales package, or alternatively is available for download from our FTP site:
ftp://ftpaccess:Brightpoint1@ftp.brightpointuk.co.uk/Technical%20Support...
You can download the software to your PC, or insert the microSD card into a suitable reader to access the software.
Once installed, on the Hero device browse to Settings --> Wireless Controls and enable the option to enable Mobile Network Sharing. Now connect the Hero to the PC via the supplied USB cable. Windows will detect the new hardware automatically and install an "HTC Remote NDIS Network Adapter": Provided that your Hero has a cellular data connection, you will now be able to use that connection from your PC.
(If you found this information helpful please rate this answer with a big thumbs up and thank you for visiting Fixya!)
Jan 27, 2010 | HTC Cell Phones
Htc hero alarm not working.... no sound when alarm goes off
I had this problem with my Orange Hero too - there is a fix but it's quite obscure.
When you're inside the "choose an alarm sound" menu and scrolling through the list,
if you press the volume buttons on the side of the phone then you can manually adjust
the alarm sound (mine was set to 0). Not sure what causes it to set to zero,
presumably when you take the phone off silent mode it sometimes fails to update the
alarm as well? This still needs looking at because it means the alarm volume resets
to zero of its own accord, but it can at least be managed by manual readjustment.
Hope this helps!
P.S. It might also be worth noting that when I was having this problem, no
third-party alarm apps would play the stock alarm sounds either.
Oct 28, 2009 | HTC Hero Smartphone
Meteor settings required for HTC hero please.
I'm a HTC Hero user on Meteor BillPay. Had the same problem and got the following solution from Meteor support which worked for me. On the phone, navigate to :
- Settings
- Wireless Controls
- Mobile Network Settings
- Access Point Names
- Meteor Data
- APN Type
Change the value here to the word "default".
Restart the phone and bob's your uncle. I did this and it worked a treat.
Sep 08, 2009 | HTC Hero Smartphone
Cell Phones Logo
99 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
