Question about Fargo DTC550 Thermal Card Printer
How to eliminate the noise on the Fargo DTC550 printer when printing color?
5 Suggested Answers
SOURCE: bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Posted on May 05, 2008
SOURCE: Fargo DTC550
My printer is Fargo DTC550 and I'm using HID 1326 card for printing. I cannot get this equipment to function correctly. I had no
problems installing the software and hooking up the printer to make the ID
cards, but all attempts to print an ID card have failed. Every card I have
tried to make has been unsatisfactory, with colours not printing, very poor
image quality, and the lamination device consistently jamming for every
single card I have tried to make.
Sir, please help me.
Showkat
Posted on Oct 04, 2008
  • 526 Answers
SOURCE: Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
Posted on May 31, 2009
  • 6 Answers
SOURCE: DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Posted on Apr 06, 2010
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
I am using fargo direct to card 550 printing machine.In that error displays "HEAD LIFT ERROR". sir how can i solve this problem and also have lots of noise is coming from the printer..please...
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Aug 02, 2011 | Fargo DTC550 Thermal Card Printer
PVC HID 1000 cards were getting stuck/bent in the Lamination module of our DTC550 printer. Talked to the tech department where we bought the printer/lamination module. They suggest because we are using...
Turning down the lam temp and dwell on the lam unit should have no effect on image color - they affect the processes only AFTER the printing of the card is complete. Make sure you were making adjustments to the LAMINATION settings, not the printing settings.
As to the noise, squeeks and groans emanating from the lam unit usually means mis-loaded lam film. Check the loading of the lam film in the printer and make sure it is not binding on the spools, and that the spools turn smoothly. Other than that, it could just be your printer showing signs of age. They have been out of production for more than 5 years, and do break down with age and usage.
Apr 28, 2017 | Fargo DTC550 Thermal Card Printer
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Not working dtc550
Since the printer prints the test page from the driver, most likely the problem is with your Cardfive software. To test this, try printing a card on the printer from Microsoft Word or Notepad. Just remember to set your page size or you will get multiple cards printed. The Fargo printer is just a windows printer and may receive output from any windows software.
Aug 02, 2008 | Fargo DTC550 Thermal Card Printer
Bad print heads
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Fargo DTC550
Showkat
Nov 26, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
26 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
