Question about Car Audio & Video
I took my radio out and unpluged it to add some wires and hooked everything back up right,,ive heard that there is a sercirty code that u have to inter???/plz plz help its a new truck
  • 2 more comments
  • teammullinsm Sep 17, 2010
    so the radio want work till i get the code right??
    so the radio want work till i get the code and inter it on the rado?
    yes it held alot but is the securty code going to trun the radio on when i enter it
    ok so when i enter code my radio will come on?
  • 2,272 Answers
The password can only be retrieved from service center or from the dealer of the unit.
Because at the back of the unit there is a serial number mentioned and the password/code only can be retrieved from the serial number. Each and every device/unit has its own serial number so one serial number code/password will not work with other serial number code password.
The service center or the dealer has the list of code for the serial number so as soon as you provide the serial number he will get the password/code retrieved for you through the list.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 17, 2010
  • raj somaiya
    raj somaiya Sep 17, 2010
    yes.As you enter the radio code the radio will come On.Its a 4 digit code.Its for safety reason actually.Because if in case the radio gets stolen by any one.Then it will not work without 4-digit code.
    so once the 4-digit code is entered it will work.
    Thanks.
Please can someone tell me where this memory fuse is for the radio. According to the forums that's what's wrong with my radio. It turns on but there is no sound. I've searched every fuse! Please help!
I never heard of a memory fuse, but you don't say what kind of radio or vehicle it is so maybe on a brand new auto but I never heard of one... Sounds like the radio took a dump, or the whole wire plug harness is unplugged or at least loose..try unplugging and plug it back in..
Jan 20, 2015 | Cars & Trucks
How can i add my add on amplifiler adapter to my back speakers?
most places that sell car stereos sell a tap adaptor kit costs about 20 bucks or more it hooks right to factory radio plug in dash and lets you hook any aftermarket radio/amp right in as all the wires are marked for there function (just match em up) No cutting and splicing required
proper kit is specific to your make and model car/truck
May 09, 2014 | 2003 Mercury Sable
1989 chevy s10 tahoe blazer the radio wiring is all messed up in the dash how to find the proper collors and fix it
I would take it to a Audio Stereo Installer, they have the Tools to test and get it right and save you so much hassle... $40 is worth saving the headache
Apr 14, 2013 | 1989 Chevrolet S-10 Blazer
1995 camaro z28 audio problems
Hi Jamie, Here's an old trick which you may find useful. Take a run down flashlight cell and confirm the wiring to the speakers by holding the earthing line of the speaker cable to the negative and flash the positive side with the feed to the speaker one at a time. With each swipe you will hear a thump from each speaker as you connect and disconnect. In that way you can confirm the cables are the ones you are connecting. Color coding is not always the same. Use a voltage test meter to confirm the constant power and ignition power and don't forget to earth the set once all other connections have been made, Withour an earth it won't work, but you know that anyway. Regards John
Dec 14, 2012 | 1995 Chevrolet Camaro
Ive hooked up all the wires from the dash to the player, it turns on an everything works except the four stock speakers, everything seems to be hooked up correctly an everyonce in a while ull hear a...
A couple of things to think about. If the radio is new, then the speakers may be bad. If the radio is not new and purchased from someone else, the radio may be bad. You are making sure the volume is turned up right? You did use a harness when hooking the radio up right? That is something I strongly recommend.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
Jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Aug 20, 2009 | JVC AM FM CD DET FACE CAR STEREO
My aftermarket radio will not turn on
I assume you didn't install the radio yourself then? Some installers put a inline fuse in. This would be located behind the radio. Some radios even have a fuse built into themselves, also on back side of radio. If those two solutions don't help ya, check the other fuses. Maybe the wiring for the radio was hooked into a different system other then the radio.
Sep 14, 2008 | 1997 Nissan Pathfinder
Radio
if the vw radio is security coded you will have to take it to a vw dealer so they can clear the code. then it should work.
Jun 21, 2008 | 2001 Volkswagen Golf
CODE ON MY HONDA CIVIC READS TUNE UP IT HAS ALREADY BEEN TUNED
I had this problem when I replaced the battery. The code is actually located inside your glove box. You have to look pretty carefully but its a 4 or 5 digit code. You enter it into the radio and wala!:) works again. Some models have to code in different local's you can google your car and find where to code is located. It took a minute to find online but be patient.:) Some one else has had the same problem. thats just for the radio. Ive heard that if turn your ignition to the second slot the one right before the car starts and leave it there until the check engine/oil light goes off. Do it ten times or so and it supposedly resets everything. Good luck!
Jun 06, 2008 | 2000 Honda Civic
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
