Question about Frigidaire Dishwashers
My dishwasher show a pf code - Frigidaire Dishwashers
  • 4,336 Answers
That means power failure. Just reset an go.
Posted on Sep 17, 2010
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
My electrolux dishwasher is showing a PF error and it will not work?
Code PF means power failure turn off the breaker that handles the dishwasher for a few mins. then turn it back on. it should reset itself
Jun 05, 2014 | Dishwashers
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Pf code comes on after normal cycle and dishes finish washing
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Feb 09, 2011 | Frigidaire 24 in. PLD3465REC Stainless...
I have pf code on the display already changed the control board same code as befor
heatman101
Feb 05, 2011 | Frigidaire Professional Series 24 in....
Just installed a frigidaire dishwasher and it shows a pf code , how do i fix this ? .
check the power and make sure its wired up correctly pf power failure.
Dec 17, 2010 | Frigidaire Dishwashers
My frigidaire dishwasher is blinking lights and a
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
heatman101
,./;''l
Jun 18, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwashers Logo
258 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
