Question about Samsung CLP-510 Laser Printer
Transfer belt error, lever unlocking error - Samsung CLP-510 Laser Printer
    Genius:
  • 1,478 Answers
There is sensor inside the transfer belt, on the bottom side of the transfer belt (pink side).You have to screw off 2 screws from the plastic cover from the pink side of the transfer belt. When you screw off plastic cover, you will see three wires which is going to sensor. There is 1 screw which hold sensor; you have to screw off that and gently pull out sensor. Sensor looks like letter U, and on the inner side of the sensor there is two small holes on the opposite sides. You have to clean that holes (blowing or with small brush). Clean it well. After that, reassemble transfer belt, put it back, and turn on printer, that solve and fix the problem.
Take care.
Posted on Sep 17, 2010
SOURCE: transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Posted on Feb 03, 2008
  • 5 Answers
SOURCE: Phaser 6100 - lever unlocking error
This printer is same as Samsung CLP-500. So the problem is the same: Contaminated transfer belt sensor.
Do as follow:
Lift transfer belt assy from printer(Drop down back door 90 degree, press white button, lift top cover and release 2 locking levers, grab handle, pull the belt unit out), turn upside down & rotate plastic roller until small clear "window" appears along one edge of belt. Clean both sides of clear window with cotton bud. on same side as window, remove 2 screws securing flimsy plastic cover to gain acess to sensor, (follow red/black wires)remove a screw and pull out "U" shaped sensor(light transmiter and receiver), cotton bud and blow away dust on slits on inner surfaces of sensor. Reassamble and everything should be ok.If not, senser may be too contaminated, clean slits vigorousley with cotton bud, or maybe you just need a new sensor.
The theory is that printer detect transfer belt by transmit light through the clear "window". If either window not clear or sensor is contaminated, light will not reach the receriver part of the sensor, printer will report such errors.
Good luck.
Posted on May 10, 2008
  • 13 Answers
SOURCE: 2 Errors
Transbelt is a part replacement-plain and simple. Samsung sucks for this, they give you no warning and just shut down the printer. www.samsungparts.com
Posted on Oct 26, 2008
  • 8 Answers
SOURCE: "Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Posted on May 06, 2009
elix0411
  • 3530 Answers
SOURCE: Transfer belt error and unlocking
Welcome to Fixya
Check and clean the sensor. There is sensor inside the transfer belt, on the bottom side of the transfer belt (pink side).You have to screw off 2 screws from the plastic cover from the pink side of the transfer belt. When you screw off plastic cover, you will see three wires which is going to sensor. There is 1 screw which hold sensor; you have to screw off that and gently pull out sensor. Sensor looks like letter U, and on the inner side of the sensor there is two small holes on the opposite sides. You have to clean that holes (blowing or with small brush). CLEAN IT WELL. After that, reassembe transfer belt, put it back, turn on printer.
Thank you for using Fixya!
Posted on Jan 13, 2011
How do you install a new transfer belt for the MagicColor #7450 printer?
Hi there !
The transfer belt is located at the right side of the printer. First you have to remove all the cartridge because the transfer belt is on the bottom of that printer. Open the right door of the printer and there is lock on both sides to free release the door cover and then there is a lever to unlock the transfer belt and pull it out to remove the transfer belt.
I hope it helps you.
Feb 09, 2011 | Konica Minolta magicolor 7450 Laser...
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
Order belt
Assuming you rprinter says Order Transfer belt on the disply you will need to order then replace the transfer belt, part number 42158711.
Open the top cover, remove the cartridges, unlock the belt unit using the blue levers then fit the new belt
Jul 06, 2009 | OKI C5500n Printer
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Dec 30, 2008 | Samsung CLP-500 Laser Printer
2 Errors
Oct 13, 2008 | Samsung CLP-500N Laser Printer
Error on printer
There is a safety lock on the scanner that may be in the locked position. Turn the unit off and locate the green lock lever/switch under the scanner where the paper comes out. It will be labeled with a icon (picture) of a lock (unlocked and locked). Move it to the unlocked and locked position multiple times, ending up in the unlocked position. It may be stuck so moving it back and forth may release it. Turn it back on and try it.
Mar 17, 2008 | Office Equipment & Supplies
Do as follow:
Good luck.
Jan 26, 2008 | Xerox Phaser 6100/BD Laser Printer
Transfer belt errors
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-510 Laser Printer Logo
728 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
