Question about GE Profile PDS20SFS Bottom Freezer Refrigerator
Not cooling enough, fridge motor runs continuosly,
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 18, 2010
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: Motor runs continuosly, what is wrong? Fridge
Therostat is stuck and need to replace immidiatly since it will create much more serius problem like compresor burning.
Until you have someone check it out you need to manualy switch it off for half an ahour every six ours or one hour every eight hours so it make the compressor relax and at the same time to have a natural defrost.
Thermostat replacing is not very expensive however compressor replacement which means freon gas recharge and freon filter can go up to $350
Posted on Sep 11, 2010
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
THE FRIDGE SIDE DOES NOT GET COLD. THIS IS A SIDE BY SIDE FRIDGE/FREEZER MODEL: RSH1DTMH
Shut offf power and then after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Also the blower fan must be checked to work continuosly , check if frost shuts off the fan.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 27, 2011 | Samsung Refrigerators
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
My refrigderator made a loud noise continuosly for about 30mins and since then dose not get cold again, only the freezer compartment gets a bit cold but not cold enough to form ice.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice built up and stopped the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Whirlpool Refrigerators
Both fridge and freezer aren't getting cold enough in my Maytag Fridge
if they are both cold, but not cold enough, one of two likely scenarios, one minor, one major. the major one, you haev a sealed system leak of refrigerant, several hundred dollars to repair.
the minor, your condenser fan motor is not running, its job is to cool the compressor, if its not cooling the compressor, when the compressor gets too hot, it will shut itself down, while the fridge continues to run. when this happens, the unit seems fine first thing in the morning, but by evening it seems less fine...while everyone sleeping, doors have been closed, allowing unit to "catch up". replace fan motor.
Feb 27, 2010 | Refrigerators
Refridgerator not cold enough. freezer is fine but temperature in the fridge is way too warm
If the unit is running continuosly it is probably a shortage of refrigerant,As the last part to get cold with the flow of refrigerant is the fridge,And would need to be leak tested,leak repaired & New refrigerant put into unit. But if the unit is cycling eg running for say 20 to30 minutes and turning off and staying off for too long,It would be advisable to replace the thermostat.Hope this Helps.
Oct 27, 2009 | Bosch Refrigerators
Fridge KIC 223L- FRIDGE NOT COLD ENOUGH
Gas; which also means that it has a leak that must be repaired and fixed. You cannot  buy refrigiation gas unless you have a license from the EPA.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile PDS20SFS Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
