Remote will not work with TV, replaced batteries a few times and we have never been able to get it to work. spike156@gmail.com
  • 8,457 Answers
Check the battery compartment for the battery - + connections might be rusted?Take something sharp like a knife or a screw driver scrap off all the rust.Clean it with a rag with some WD40 to clean the - + battery compartment conection.Put the battery back in about half hour later to reset the remote.Should work,i did mine work fine.Not than the remote CPU it dead.Try website like Remotes.com to buy an exact same remote to the original or very close compatible one.
Posted on Sep 17, 2010
Remote will not work tv.
A working TV remote is a security blanket that allows us the peace of mind of knowing that we don't have to get up unless nature calls or the house catches on fire. People are more likely to spend more time and energy to fix their TV remote than to get up and change the channel. There are a number of simple fixes that can ease your mind when your TV remote is not working.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New Batteries
  1. Check the batteries. Make sure the batteries are in correctly and, if they are, replace the batteries. If the batteries are dead or are not in correctly, your remote will not respond and the LED light will not illuminate when a button is pressed. Make sure the TV is plugged in. An unplugged TV will not respond to any remote.
  2. Check the selected input to make sure the remote is set on the TV and not some other device programmed into the remote, such as your DVD player, VCR, or video game console.
  3. Reprogram the sync code. If you are using a universal remote, it may have deprogrammed, leaving the remote and TV out of sync.
  4. Unplug the TV for a few minutes. During a power surge, a TV can become "confused." Unplugging it for a few minutes will give the TV the break it needs to sort everything out and work properly with your remote.
  5. Use another remote on the TV. Program a universal remote to work with the TV. If the TV does not respond, the problem is likely with the TV and not the remote control.
Jan 09, 2011 | Toshiba 62HM95 62" DLP HDTV
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Oct 12, 2010 | Sony KP-61HS30 TV
We have a viewsonic tv and the remote control has stopped working after just two years. How do we now if it is the tv that the problem is or the remote
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals. I would get original from Viewsonic to get full functions. Look out for caps to go bad in your power supply also.
www.viewsonic.com
Parts: www.shopjimmy.com,
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 07, 2010 | ViewSonic N4251w 42 in. LCD Television
I have a dish 625 box and duo tv's. #1 remote works everything, but remote 2 will not turn tv on or off or control volume. Tech did have both of them working originaly but we had some issues and now cannot...
grandygram,
I have provided a link on programming your TV 2 DISH remote to your Philco TV. Here is the link:
http://www.dishnetwork.com/SupportSection/remote-setup
The steps are towards the bottom of the page. The codes that have the highest success rate are listed below.
566, 653, 654, 655, 656, 659, 660
I hope this helps.
Ray Calo
DISH Network
Apr 23, 2010 | DISH Network DVR-625 DTV Receiver /...
The remote control for our Technika lcd 26-207 doesn't work.
Sounds like maybe the remote receiver on the tv itself has gone faulty if a replacement remote doesn't work.
email me on markiexxxx (at) gmail (dot) com
for more info...
Sep 29, 2009 | Televison & Video
I AM UNABLE TO CHANGE CHANNELS USING RMT D175A PLEASE HELP
Is this the first time you've tried using this remote with your TV or has this problem just started?
If it's a recent problem, be sure you put FRESH BATTERIES in it. Some remotes will forget everything if the batteries are weak.
Then, try this site:
http://esupport.sony.com/perl/model-remote.pl?mdl=RMTD175A
You can enter your TV brand and it should walk you through re-programming your remote.
Jul 08, 2009 | Televison & Video
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
