Question about Whirlpool Inglis IP4400 Washer
Washer stops on nf code but water lines are not plugged
jsrock516
  • 5911 Answers
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on May 13, 2007
SOURCE: Error code
nF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. This also can occur if there is a whole-house water softner, well-water, or very low water pressure.
Posted on Dec 04, 2007
SOURCE: I have a Maytag Model MAH8700aww washer
Posted on Dec 12, 2008
WRMtech
  • 70 Answers
SOURCE: Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Posted on Feb 19, 2009
  • 219 Answers
SOURCE: My washer has been stopping and displaying code nf. What do you think is wrong?
needs a watervalve replaced
Posted on Apr 17, 2009
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
The NF light comes on
The nF error code stands for "No Fill."
If you have just installed your washer and it will not fill, or the display shows nF, check the following:
  • Make sure the door to the unit is tightly closed.
  • Make sure that both the hot and cold water lines are connected (cold to the cold and hot to the hot)
    • Note: If you do not have a hot water source, you can hook up the cold water source to the cold input on the back of the washer and another cold water source to the hot input on the back of the washer (but NEVER a hot water source to the cold water input on the back of the washer).
Oct 14, 2012 | Samsung WF337AA Front Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
you need to sort this part out level sensor located near to the door switch and main board.
samsung boardpng-vn1wiordb5lxotmqu1or3lil-1-4.png wiring will be similar to this. might have a blocked air feed from the drum don't blow into the sensor take the clear pipe off and blow down that to make sure its not blocked, washing powered and stuff can block the line.
Jan 13, 2018 | Washing Machines
We start the washer and it runs for about 20 minutes. Then it stops and the letters nf come on the control panel and it wont run. Can you please what that means?
According to the user manual for your washer (which is available here, http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206687.pdf), "nF" means the washer is unable to fill with water. Make sure your water supply lines are free of obstructions or kinks, and also that the water valves are turned on all the way.
Jan 29, 2011 | Maytag Neptune MAH6500A Front Load Washer
Nf error code
The NF error codes stands for no fill. This is usually caused by hard water deposits in the fill valve screen. Youl will need to disconnect the water lines to the back of the washer and clean then out thoroughly. This should solve you problem, please rate my response if it helps you:)
Dec 02, 2010 | Kenmore Elite 45986 Front Load Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stops with "nf" displayed on screen
nf is no fill
with samsungs most of the time its a bad resistopr on the cold water vale itself,
check your screens though
Oct 03, 2009 | Samsung WF337AA Front Load Washer
Error code
My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
Nov 28, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
