Question about Kenmore Dryers
I have kenmore serial#131764100 9805 stacked washer dryer combo. the dryer heater came on in a flash, then went off permanently. the tumbler still goes. i think its gotta be the fuse! where would the fuse be?
aborcass
  • 2651 Answers
SOURCE: Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Posted on Feb 23, 2008
SOURCE: How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Posted on Jun 26, 2008
  • 5 Answers
SOURCE: stacking kenmores
Yes. When I bought my washer and dryer, it came with the stacking kit.
Posted on Nov 24, 2008
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dryer makes loud noise
Probably a bad set of glides.
ea82af1.jpgor worse.Check out my BLOG on this
Posted on May 20, 2009
Dryer not heating up trying to figure out where fuse is located
some tumbles have a rubber circle reset in the centre of tumble at the back,this is the thermostat.if not they may be internal.they are metal circle things,they may need replaced.id say a new thermostat is needed.may also be the heater element,need more info
Mar 19, 2013 | Kenmore Dryer /stacked Washer Washer Dryer...
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore 417.94812301 staked washer / dryer problem
Your dryer was made by Frigidaire and needs what is called a rear bearing kit (#5303281153 costs about $30) from frigidaire.
there is also a good chance that your bearing failed because the dryer overheated (overheating is mostly caused by the venting being restricted)
Oct 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
545 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
