Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Cannot boot - goeas into start up repair. Diagnostics test show errors with hard drive error code 0f00:075d
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
If you are running the Dell diagnostics and you get this particular message then the problem is with the Hard drive and it needs to be replaced.. Please call Dell at 18006249896 if you are in warranty so that they will provide free of cost.. Out of warranty.. Get a new hard disk from a local shop...
Posted on Sep 17, 2010
How to Troubleshoot Window Computer Error Code 0146?
Sounds like a Dell error code.
Error code: 2000-0146 (DST Log contains previous errors) refers to previous errors in the hard drive which might not really be a hardware failure. In order to confirm this, I recommend you to run a custom test on the Hard drive which takes longer time than the Pre-boot System Assessment which you have already performed on the computer but it will give the accurate result.
Once the Pre-boot System Assessment is completed, the computer will give you an option to "Run the remaining memory test", please select "No". Then the computer will launch the 32-bit Diagnostics from the utility partition (if available).
After the diagnostics is launched, in the main menu, please click on "Custom Test", then select the "Hard drive" and click on "Run Tests". If the test completes without any error then the hard drive is fine and PC Restore can be performed to restore the computer back to the factory condition (which will result in data loss).
Jun 29, 2018 | Computers & Internet
Hello when I try start my laptop I get a little blue box saying : selected boot image did not authenticate. Press enter to continue. When I do this it shuts itself down. I tried starting it in safe mode...
There are serious errors on you hdd and the system sees it as a hdd failure and consequetially it won't boot. Place your OS disc in the dvd drive, boot from it and choose repair.
Jul 28, 2014 | Computers & Internet
Dell error code 2000 0146
That Dell error code indicates a hard drive issue. The link below has some information about running Dell hard drive diagnostics which don't require being able to boot to Windows. (There are other ways to test the hard drive by booting with a Repair CD or other tools, but the Dell test should be sufficient.)
Jan 16, 2014 | Computers & Internet
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Comoputer: DELl precision T5500 Workstation Problem: cannot start normally Error CODE 0142 Msg: Error Code 2000-0142 Msg: Hard Drive 0-Self-test unsuccessful Status: 72
sounds like a bad hard drive. Press f12 during the dell logo on startup and choose "diagnostics" from the boot menu, see if more failures relating to the hard drive are returned.
Feb 23, 2011 | Computers & Internet
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    A hard disc error is preventing windows from starting, Then opening up the start up repair problem details says; problem event name startup repairv2 problem signature 01 ...
    the hard drive should have diagnostics under the bios run on it..
    get in the setup area right at the beginning on the starting process... like hit F2.. right away at boot up
    see if there are built in diagnostics for testing your hard drive... this is usually the case
    if not
    get a copy of seagate or western digital diagnostics testing software and place the software correctly on a cd... boot from the cd... and execute the diagnostics on the hard drive in the laptop
    this will determine if the drive is good or not
    tell me the answer and we will solve the problem from there
    Sep 29, 2009 | Acer TravelMate 5520 Notebook
    My dell inspiron 1525 won't boot up
    The hard drive could be failing. Try running the test this way.
    First you'll have to power off the system.
    You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode.
    After running a series of tests you'll be prompted to "Press any key to boot to the diagnostics partitions". Now you'll get a prompt to test the computer. You need to select the option and run a CUSTOM TEST on the hard drive.
    Write down any error codes listed and continue testing.
    If you get any errors note then and contact technical support.
    Aug 19, 2009 | Dell XPS M1530 Laptop
    Error code 0146 , can you help me ?
    ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
    If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
    Look at the bios and see if the hard drive is detected.
    To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
    Press F2 for boot options
    Press F12 for setup
    Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
    Check also that it says enabled
    Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
    you should get a report when it finishes looking something like this:
    DST Short Test: Failed
    Error Code: 1000-0146
    Msg: Unit 2 : DST LOC Contains previous error(s)
    READ TEST:
    0F00: 0244
    MSG Block: 57301297
    VERIFY TEST:
    0F00:1A44
    MSG Block: 57301297
    if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
    Oct 21, 2008 | Computers & Internet
    Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
    606 people viewed this question
    Alun Cox
