Question about Cosco Alpha Omega Elite 5-Point 22-155
In order to change from the toddler seat to the booster for a child over 40 lbs, what do I do?? does the seat just become attached to the car by the seat belt? does it need to be attached by other straps?? does something come off of the car seat?
    Sergeant:
  • 168 Answers
please feel free to call at 1-800-544-1108 and they can send you a manual in case you dont have it.
*To convert the car seat into a booster seat, turn the car seat over and remove the pin that holds the base in place. tHEN REMOVE THE BELTS AND THE BUCKLE.
*To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused
PLEASE RATE MY HELP :)
Posted on Sep 17, 2010
Manual
You can find manuals for Evenflo car seats here:
http://babycare.manualsonline.com/manuals/mfg/evenflo/evenflo_car_seat_product_list.html
You can also contact customer service directly:
Evenflo Company, Inc.
1801 Commerce Drive
Piqua, Ohio 45356
Nov 16, 2012 | Evenflo Convertible Car Seat Booster...
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
Does the car seat need to be bolted to the car when the harness is removed for a child over 50 lbs?
I have a similar car seat for my 4 year old. You should check your local laws about how long they have to use a car seat. Depending on the situation, if it's leaning around to far you may just go without it. I've never seen a model that is 'bolted' to the car. Most of them at the booster stage are held in by the childs weight and the safety belt in the car. If it has straps for the 'Latch' system, and your car has latch mounts, you might do that to help stabilize it.
Hope this helps! Don't forget to rate!
Gtaplytmpt
Jul 18, 2011 | Graco Nautilus 3-in 1 Car Seat
From which age can you child go on this chear?
Hi nicole terho
After reading the solution to your problem could you please rate if my answer was helpful thanks...
According to the car seat these are the details i found on the web
Recommended Use:
  • 5-point harness: 20 to 65 lbs.
  • High-back booster: 30 to 100 lbs.
  • Backless booster: 40 to 100 lbs.
Hope this helps cheers nikki
Jan 20, 2011 | Nania Nuevo 3-in1
When installing the forward facing booster seat do you not hook in any of latches to the seat? We have model #22-757-MRC. My children are over 40 inches so I am swithching them to the booster seat. My...
your child's weight and the lap & shoulder belt hold the seat in place.  Run the lap part across your child's lap and the shoulder part should cross your child's chest and not cross his/her neck.  There should be some slots on the side near the top to allow some adjustment of the shoulder strap.
Sep 06, 2009 | Baby Gear
Minimum Child weight for booster
Most seat-belt positioning boosters require the child to be at least 30 pounds. Many states say 4 years old and 40 pounds is the minimum.
Maturity is by far the most important thing, though. The child isn't ready to be in a seat-belt only booster until he can be trusted to sit up with his back straight and his bottom back ALL the time - if he moves around, the seat belt will not stay in a proper, safe place.
A seat with a 5 point harness is infinitely safer - in an accident, a child in a seat-belt positioning booster can be thrown forward and around the safety wings of a high back booster or, with a low back booster, be thrown into the sides/seats of the car - both substantially increase the risk of head injury. They can also slip down under the seat belt (called submarining), which can cause major internal injuries.
If you are determined to make the move to a seat-belt positioning seat, though, here's my thoughts on the two we've tried. The Graco Turbobooster is very popular with our friends, is inexpensive, easy to use, etc. Personally, we prefer the Compass B-510. It is more expensive, but it seems a LOT sturdier and has a bigger, nicer headrest/side wings with EPS foam for side-impact protection. The arm rests also flip up, to make it easier for the kid to get in and out and to do the seat belt. It comes in lots of great patterns, too...my oldest son adored his camo print booster and rode in it with no fuss until after he turned 9. He says it is WAY more cushioned and comfortable than the turboboosters.
If I can talk you into staying in a harnessed seat =) .... Most of the less expensive 5 point boosters only harness to 40 pounds, but Graco recently put out the Nautilus, which harnesses to 65 pounds and then converts to a belt positioning booster, so you can get years of use out of it. It's considerably less expensive than most of the other higher harness weight seats (i.e. Britax Regent, Sunshine Kids Radian) - we actually own all three of those varieties, and I like the Nautilus just as much as the Regent and MORE than the Radian.
Another less expensive higher harness weight seat is the Apex 65, but it requires the seat of the CAR to be at least as tall as the child's ears...when the child's ears reach the car's seat back, it's outgrown, because it's headrest isn't reinforced like the others are. Unless you have really tall seat backs, it won't last you nearly as long as the others. It also is supposed to turn into a belt-positioning booster, but I've heard from numerous people that it's really no good as a belt positioning only seat.
Dec 03, 2008 | Baby Gear
Booster
Remove straps and belt across the lap!
Nov 04, 2007 | Eddie Bauer Deluxe High Back Booster...
Child Harness for the Cosco 22560 Child Seat
Try calling their Consumer Relations Department at 1-800-544-1108 where you can speak to a Consumer Relations Representative to order the parts. Hours are: Monday ? Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
Jul 14, 2007 | Cosco 22560FLG
Cosco Alpha Omega Elite 5-Point 22-155 Logo
623 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
