Question about Samsung Dryers
Not getting any heat in my drier. I have cleaner out the unit and vents, installed a new ellement and have confirmed that the two thermostats have continunity. What else is there???
  • Samsung Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
My dryer heats but takes two cycles to dry clothes.
Check the hose in the back and vent to make sure it is breathing properly first. Most driers have a thermistor moisture sensor. Try replacing it first. It nether of these works your heat strip may be shorted so only heating partially. Most driers have two or three thermostats also. Two on the heater cover. One is the high temp and one is the low temp. Usually the high heat will be the problem (cuts out to early before the heat strip fully heats). Others have a third one on the exhaust blower. Check these at room temprature with an ohm meter. They should have continuity. If not replace. Thermostats that are open with no continuity will usually cause the heater not to heat at all. Thermostats can get old and stop working at their intended temp. Replace one at a time
Jan 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Bloody washer dryer Hotpoint wd420p 606200214
at what point is that getting heated up actually?
Jan 22, 2008 | Washing Machines
Maxi dry 456 not heating
not necessarily the ellement is the main cause although most of the time it is the ellement that cause the problem...because of poor terminal contact from the power source.The timer of the drier also when mal function will cause the problem you need to clean the contact of the timer..need to check also whether a termistor and termal fuse is present on the circuit.use a tester to check the continuity of the termal fuse and termistor replace if open..
hope this could help you.Goodluck!
your rate culd help this post tnx..
May 21, 2010 | Dryers
Dryer does not heat ellement is good
If the dryer won't heat and the heating element is good, then check the thermal fuse and the high limit thermostat. The thermal fuse is located just inside the rear of the dryer and is mounted on the exhaust duct. Test it for continuity using a multimeter. A lack of continuity indicates a blown thermal fuse. '
The high limit thermostat is a small round, black device mounted on a metal plate and attached to the internal ductwork with two screws. It can be tested for continuity. It should have none. If it has continuity it is faulty. I am attaching a photo of the thermal fuse and high limit thermostat for reference. Hope this helped and best wishes.
Aug 09, 2009 | Dryers
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Noisy and inconsistent cooling
It could be that there is a problem with the Thermostat\low voltage switching. Some heat pumps have reversing valves activated for cooling , sometimes for heating. Whoever installed this for you is totally responsible for your unit still. There can be a number of things going wrong, like no filter drier in stalled and sporatically clogging the refrigerant and making a lot of noise. Call the installer back.
Jul 13, 2009 | Heating & Cooling
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryer takes a very long time to dry clothes
dear sir you could check that your vent is clear and the trap outside is not closed or cloged to test your dryer disconect it from the vent if drys good then your problem is in your vent tubing if it does not dry when you have disconected from the vent then check the wire to the ellement most dryer have 2 ellement inside one may be broken this will take a long time to dry if you have a amp probe you can tell wrigh away by checking the total acording to the spec plate on the machine thanks from gilles
Mar 15, 2009 | Dryers
No Heat
yes possible ellement burnt out or themofuse burnt out thermofuse is a small white or black device witch is mouted od the back of the interior panel about 1"
longif it has ovrheat this fuse will cut out the power to the ellement or if the vent outside was cloged thanks from gilles
Heating Element no longer working
Hi Paige
Expect to pay $30 for the kit. it's a 279816 and will take some level of mechanical and technical ability to locate it and affect the repair. This kit addresses 2 issues and should be installed by a certified technician. Your owners manual has a big WARNING!!! block saying what not to do, like Don't use plastic or foil venting. But nobody reads manuals anyway. Most likely you have an aluminum foil colored accordian style vent pipe. That's what caused your thermostats to burn out. Get your drier checked out by a certified tech for safety. Afterwards, keep that vent, clean clean clean and install a sure vent from Whirlpool 4396028. 16,000 homes each year have fires from improperly vented driers according to the U.S. Dept of Consumer Safety.
Dec 10, 2008 | KitchenAid KEYS750LQ Electric Dryer
Dryers Logo
52 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
