Question about Car Audio & Video
Need to find out what the wires stand for which color is for whAT
  • 3 Answers
What is the vehicle make and model
Posted on Sep 17, 2010
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
Need to replace- looking for a package insert to identify the wires exiting the back of the switch
Brand of dimmer? All my Lutron dimmers have 3 or 4 wires, and if it's a simple stand alone, it's two black wires and a green one. green is ground, the others go one to hot, one to the lamp.
If you have a white one and a black one, black is "hot", white goes to the lamp.
May 09, 2015 | Electrical Supplies
How to replace power cord on kitchenaid k4-b?
Take the four screws off that separate the top of the mixer from the stand,they are just above the handle that locks the bowls up when mixing.once you get the top off you will see where the wires connect to,simply disconnect the wires,remember which colors go where,because when you put the new cord on you will need to know where each color goes,it pretty straight forward,once cord is screwed in,put top of mixer back together and the screws are evenly tight.plug it in and mix away,if there's no power orbit sparks unplug right away and check wires ,to make sure you got in right spot and they are tighten down all the way.
Jun 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Igntion wire colors
IT IS BEST TO EITHER VISIT LIBRARY OR GET A HAYES/CHILTON BOOK THAT COVERS YOUR CAR THEN YOU WILL HAVE COMPLETE WIRE SCEMATICS AND KNOW WHAT COLOR AND ITS USE
Mar 09, 2014 | 1998 Chevrolet Cavalier
Speed switch wiring
You can get a three speed switch almost anywhere, but if you want the correct one then I need to know how many wires are on the capacitor & what color wire goes into which slot of the switch.
Aug 28, 2013 | Haier FSW116W Stand (Pedestal) Fan
What does o/w mean in a 2001 heritage softail wiring diagram?
That is the abbeviation used for the color of the wire. Yours is an orange wire withe a white tracer line going around it. IMPORTANT*
Do not confuse o/w Orange with a white tracer line with w/o White with an orange tracer wire. The first letter in o/w will stand for the primary color of that wire, in this case Orange.. It will be a bit thicker width on that wire. The second letter, in this case White, will stand for the tracer color, look closely, the tracer line is thinner than the primary line. This is so you can more easily trace wires on your bike. There will be more combinations of colors used on your bike, but they will all follow the same rule. Primary color is the first letter and is wider or thicker/ Tracer line is the second letter and the line will be thinner than the primary.
Apr 18, 2013 | 2004 Harley Davidson FLSTC - FLSTCI...
I have a intermatic ET1125C I have 30 amp fused load coming in,how EXACTLY do I wire it in and TWO independent outs for load 1 load 2 ? The diagrams are confusing I need to know color wire to #1-6 on the...
10-22-12
Intermatic ET1125 240Volt, two independent circuit Wiring absolutely shows on following link: Wire colors can vary. 240Volt line can be black-white, or red-white, or black-black. Non-code wiring can be white-white.
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html#1125
I have no idea what color wires you have. Or if circuit tests for 240V.
Include a photograph of your wiring, and list showing voltage on each wire, and color of each wire, and description where each wire comes from.
You should have two Hot wires L1 L2 coming from 30 amp breaker.
And 2 wires going to each Load (light, fan, motor).
Wire size should be at least 10 gauge.
Turn power ON, stand on dry boards, tape tester leads to wood sticks, and test each wire to bare ground.
240Volt circuit will have two hot wires.
Oct 22, 2012 | Hardware & Accessories
Need capacitor wiring diagram
No model number gotta shoot from the hip on this one:
The cap has 3 sections: Herm for compressor, F for fan, and C for common.
The common section of the cap gets a hot wire off the power cord, a wire from compressor marked C on compressor and a white common wire from the fan gets connected to C on that cap. These wires are almost always white in color on American OEM. The fan has a small brown wire that connects to F on tha cap. The compressor has a wire marked S on it make a note of that color wire and connect it to the section on the cap called HERM. Herm stands for hermedtically sealed compressor. So both your commons and a hot wire go to C. You need one small brown wire which goes to F from the fan. One wire marked S on the compressor goes to Herm for compressor starting. S stands for start winding.
Lets look at typical American fan motor wires: The fan has a black wire for high speed a blue wire for medium and a red wire for low. It has white wire for common, and a brown wire for capacitor. Connect your common fan wire to common and the brown wire to F.
With that cap properly connected basically all you would need to do to make it run is connect a fan speed, the compressor wire marked R for RUN, and and the other power wire.
Jul 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
What distance does the back and sides of the wall oven need to be from the other kitchen cabinets and drywall? What is the voltage and wattage of wall oven? What do the five colors, blue, black, green,...
the installation instructions are in the user manual and the wiring must be done by an accredited , qualified electrician
do anything yourself and the warranty is void
Aug 14, 2017 | Ovens
Im installing a new radio but I don't have a harness in my car how would I do this? What do the wiring colors stand for? Can I please get the labels on the color wire for the stereo set up.?
Commonly, the color codes vary from manufacturer, please check the link below to see if they match with your wiring color codes and also see the image below of a typical head unit wiring:
http://www.autotoys.com/New_Tech/Wire_codes/wire_codes.htm
Mar 07, 2011 | Car Audio & Video
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
