Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do you reset the Whirlpool Cabrio control panel, besides unplugging it?
  • 83 Answers
Press stop/cancel to clear the display
Posted on Sep 17, 2010
    Sergeant:
    Champion:
  • 333 Answers
Between the wall of the washer and the tub is a repair manual taped to the inside wall it is the how to manual for the repairman. Lay the washer down on its back and look inside from underneath grab the manual it will tell you how to re-calibrate your machine you have to push a series of buttons and turn the dial a certain way. You need this manual
Posted on Jan 08, 2016
I did that and it still want work.
Posted on Oct 18, 2011
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
Mar 29, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
F1 Code.
try unplugging it for a while to reset the control board,if this doesnt work then theres a bad control board or interface keypad,you will need to run the diagnostics from the sheet located under the control panel to determine which board is defective
Jul 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting a F1 code, how can I reset it. Can afford professional service.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Where is the reset button on Cabrio dryer wgd6400sb0 start button keeps flashing and won't start
there is no reset, unplug the unit for 5 minutes, if it still won't start you have a CCU problem, that is the central control board.
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio is showing AF on panel
AF is not a valid error.
Unplug for 40 minutes and re-try to reset ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer WTW6600S turns on but does not do nothing
Try unplugging it for a few minutes then plug it back in. If it does not reset then the controller requires replacement. Hope this helps... Bill
May 31, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't start
If unplugging the washer for a few minutes does not reset the main control then the electronic control board is likely shot but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
This will help: Repair Manual - Cabrio top loading washer
For Whirlpool Cabrio washer parts CLICK HERE
www.RepairClinic.com
Feb 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
2,766 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
