Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
My GE Artic Profile refridgerator blows warm air on both sides Model number PSS25MGNAWW SER #420869
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
Is there a recall on the motherboard of ge profile artica model pss25mgnaww
From what I see online, there seems to be. Call GE and mention recall of part # WR55X10942 and see what they say
Sep 08, 2017 | GE Refrigerators
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
How do I set the clock on my Samsung microwave
Your model number refers to refridgerator.....see this link
www.manualslib.com > Brands > GE Manuals > Refrigerator
Jan 17, 2015 | General Electric GE Profile CounterTop...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I need the schematic for a GE model GSS201EPHWW side by side refrigerator
Your model shares the same basic wiring as the PSS26MSRSS, Artic and Profile, Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION Click Here for=> Service Manual
I will be here if you have any questions, Thanks Sea Breeze
Aug 22, 2011 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerators Logo
358 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
