Question about Tools & Hardware - Others
I am trying to start a Coleman evcon model dgat075bdf gas furnace. I am getting 3 blinks from the control board, and there is not power to the combustion blower. I have turned the system off for 1 minute, with no effect. What is my next troubleshooting task?
    New Friend:
I fixed my 3 blinking issue: I pulled off the small blower motor above the vacuum sensor and spun the fan with my finger. It had resistance at first but then it spun freely. I put everything back together and it ran. I figure next year I may have to buy a new motor, but I made it this year. By the way that fan creates the vacuum to allow the sensor to work. It is a safety thing I figure. If the fan seizes up again the unit will sense it and shut down.
Posted on Nov 10, 2012
  • 115 Answers
SOURCE: Evcon Coleman mobile home furnace needs repair
if you know what the flame sensor is try gently cleaning it with sandpaper they get gummed up sometimes and don't sense the piolet flame, if they don;t see a piolet it will not allow it to kick the gas on
Posted on Oct 10, 2009
SOURCE: evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Posted on Mar 06, 2009
  • 221 Answers
SOURCE: i have a coleman evcon furnace and it wont work it
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Posted on Dec 31, 2009
  • 221 Answers
SOURCE: COLEMAN EVCON FURNACE .. The draft fan keeps
Make sure the Thermostat fan switch is in the "auto" position.
  • 221 Answers
SOURCE: need schematics for coleman evcon presidential
The schematic is inside the panel where the wiring is.
Indicator blicks 3 times replaced combustion air switch but did not resolve problem. what do i do now?
there should be a diagnostic code that will tell you what 3 blinks mean for that model. look on door inside cover. tell me EXACTLY what it does at start up. small draft motor comes on? you see a glow from hot surface ignighter? gas comes on? flame on? it should run in this order.
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman furnace bgm10016ax 4 blinks
Usually on a metal panel you have to remove to access the board there is an electrical diagram. On the side of that is usually a description of what specific blinking codes mean.
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have an Evcon furnace Model # DGAT075BDF. It
Does your fan work from the on position. New tstat may have RC and RH need to jumper them. If that does not work. Turn on tstat check voltage on board at furnace between w and c if you have voltage you may have a bad board. Also see if there is any reset buttons like on the roll out switches. Smaa red buttons. Push them to reset. Let me know what going on. Rus
Dec 03, 2009 | Heating & Cooling
Tools & Hardware - Others Logo
391 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
