Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
I have a sony wega kdf 55e200. When i turn it on i get maybe 4 green flashes of the power light, followed by 3 red flashes. I've already spoken to tech support and they've explained to me that it means the door isn't closed properly. Since then, I've carefully reinstalled lamp and doors several times only to fail and get the same 3 flashing lights. Is there anything else I can check or do?
  • Sony Master
  • 8,457 Answers
Tries unplug,replug tv an hour later,that a reset tv back to factory setting.See,that solved ur problems.Not, than the lamp u have might gotton shorted some how.Buy a another lamp.Tries the same process.
Posted on Sep 17, 2010
Power light flashes green likes it turning on then flashes red 3 times. I just replaced lamp Sony Grand Wega KDF-55E2000
3 blinks should on this model mean "LAMP DOOR IS NOT CLOSED" BUT IT really means something else.
Can I assist you?
I can tell you how to prove this or not and if proved it is a simple and not expensive repair..
SD TECH
Nov 10, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
Jul 13, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Grand Wega turns off and comes back on
sounds like your lamp is getting weak, you need to replace it.
Jan 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
274 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
