I need a service manual for bosch washer model wfmc2201uc
  • Anonymous Mar 14, 2014
    erroe
    e02
  • Washing Mach... Master
  • 17,130 Answers
You can get support from the main home site of Bosch but they do not share service manuals to customers. So log on and postt your querry to :
www.bosch-home.com/us/WFMC2201UC.htm
There is a link for you to check out for the manual and ZI hope it will be useful; Just try this link:
www.retrevo.com/support/?Bosch-WFMC2201UC-Washers-manual/id/925ci467/t/?2
Posted on Sep 17, 2010
I own a Bosch 300 Next Series Washer and the door and drum both seemed to be locked. I need to know if there is anything we can try to get the door open?
Hi well whenever this occurs it is usually to do with the main controller board, simply it needs to be replaced. If you wish to DIY, then you will need to obtain a service manual, in order to perform the troubleshooting steps, just to ensure that the main board is actually the culprit, and also to enable the parts to be obtained, via the parts numbers in the manual.
However it may indeed be best if you contact the local or head office from Bosch, and ask for a referral to an authorised service center, then make contact there and ask for a service call, now when and only when you are face to face ask for a "Quote" ONLY. Then at the least you will be appraised of the problem and the potential costings. Then at the least you can make up your mind as to repair or replace?
Oct 10, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
E13
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
Here the tips... support/t7599677-error_code_13
Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Putting on spring loaded wire seal ring on a bosch washer
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.
how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Jun 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Bosch washer too long cycle times
Looks like the heater has failed.Contact Bosch direct to repair as it has a 2 year guarantee
Mar 15, 2008 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
