Question about GE Refrigerators
I have a ge profile bottom freezer fridge model PDS22MCR. It's making a loud humming noise & the fridge & freezer are getting progressivley warmer. fridge is up to 45 & frezzer 11 in a matter of minutes. This happened the other day, we emptied all contents & by morning it was back to normal temps. Today I cleaned it out & started refilling & its happening again! Please help :) Something in the freezer section seems to be running. cheryl
  • GE Master
  • 43,501 Answers
The compressor is not starting every time and later it will start again...replace start relay and capacitor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
I have a GE Profile PDS22MCR bottom freezer. The freezer is getting colder and the fridge is getting warmer....... What could this be?
your damper assy isn't opening to allow cold air from the freezer up into the refrigerator,its located on the rear wall in the refrigerator compartment,you need to make sure theres a fan running in the freezer,then if so you should feel cold air blowing up in the refrigerator compartment,remove this panel and see if its shut,if no air is felt then the damper door is either broken or jammed shut or if its o.k.,then your control board in the rear of the unit could be defective not letting power to the damper door or even on of your thermistors in the side walls of the refrigerator that monitor temps in the refrigerator and freezer could be defective
Sep 28, 2012 | GE PDS22MCR Bottom Freezer Refrigerator
I have a GE Profile PFSF5NJWA has alot of frost building up in the freezer. After a while, the fridge makes a loud humming noise at which point I have to clean out all of the ice to get it to stop. However...
you have a defrost problem the defrost system consist of three things a defrost control, a defrost t-stat and a defrost heater it's hard to say which one of the three it is without checking it with a meter
Nov 20, 2010 | GE Refrigerators
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Noise
Most likely the fan is hitting some frost inside. Defrost the fridge by unplugging it for 24 hours and see if it helps.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | GE Profile Bottom-Freezer Refrigerator...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
