Question about Hitachi Nv45ab2(s) Coil Roofing Nailer
Fires the first nail and will not fire the second. But makes the hit on the wood, so I know it shoots but it's the nail that will not move into the chamber to go next. Oiled the parts and still the same thing, fires one nail fine and nothin else?
  • 2,100 Answers
Either the nail thingy that pushes the nails through is worn, broke, or shot, or you have the wrong nails in there and it is not grabbing them as it should, I think the part is broken on the inside, can't really tell without seeing it, but if it spins free, you need to check it out. Might be able to weld it. Or just replace it. Hope this helps.
Posted on Sep 17, 2010
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
Hitachi NR83AA shoots two nails on one pull of the trigger?
Best practice is to bump fire the gun to prevent double fire. Do not place the gun on the work and pull the trigger. This takes practice while using at an angle. Works better if the nose piece has rather sharp points to help nose to stay in postion while you bump. With trigger depressed, practice without nails bumping/hitting wood at different angles untill you can bump hit at the spot that you need the fastener. If the gun double fires while bump-firing, most likely all the safety/trip parts are worn/loose. Not expensive to replace. Good luck.
Jul 05, 2012 | Air Tools & Compressors
My gun has always from day one punches out 2 nail and jams up or not, is there an adjust ment for this problem
Nailers will double fire or at times, the driver will hit two nails with one stroke. The first issue is caused by sensitive trigger or worn orings and the second problem is caused by faulty nails (too close together in strip ) or the driver is bent slightly allowing the driver to strike the head of the second nail in line. One way to prevent double fire is to use the single trip trigger (usually white plastic). With this trigger, you must lift the gun off the work, release the trigger and press the gun against the work and pull the trigger. If you are using the black bump fire trigger and it double fires, replace the trigger valve. The issue of the driver blade hitting two nails with one stroke can be solved by examining the driver blale for damage. The blade should have a taper on the side that faces the nails. This taper is there so that as the driver hits the first nail the taper will gently push the rest of the nails slightly into the rails out of the way. If generic nails are used, make sure that the nails are designed with the proper spacing and angle. Easy test. With the gun on its side, place a strip of nails on top of the rails with the heads aligned with the angle of the rails. Move the strip of nails so that the first nail is in the path of the driver and the heads are still aligned with the rails. The first nail should align perfectly with the angle and path of the driver. If the head of first nail is in the path of the driver however the shaft of the nail is angled toward the rails, the driver blade may hit two nails. If the point of the first nail is in the path of the driver and the head is angled back toward the rails, you may have miss fire. If the nails are perfectly aligned with the rails and the path of the driver and the driver is hitting the second nail, grind more taper at the bottom inch of the driver. Good luck
Oct 14, 2011 | Stanley Bostitch N88rh Framing Nailer...
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Sometimes fires 2 nails at once not all the way in and sometimes dosen`t shoot a nail in at all. I only use Bostitch nails
you would need to check the driver/piston for problems and make sure that you are using the right guage nails. Let me know what you find and I will try and help further.
Jan 26, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Mastercraft Brad nailer piston always fires damaging finish but nail gets randomly shot. Thought it was a indent before nail shot to indent nail since it mostley shoots nails after second shot but lately...
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Apr 13, 2009 | Tools & Hardware - Others
Nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Mar 12, 2009 | Air Tools & Compressors
Hitachi Nv45ab2(s) Coil Roofing Nailer Logo
126 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
