Question about Maytag EPIC MFW9700S Front Load Washer
What does the code F8 mean on maytag front loader washer?
SOURCE: Maytag Neptune Front Loader - E2 error code
When I originally called maytag service they didn't know either, they had be down for a different code. However, when the tech came and called his tech support, the stated that it was a code meaning that a button had been pushed and held down for more than 30 seconds. The first thought my 4 year old had done it - I told him he didn't stay still for more than 30 seconds let alone hold a button. As for the vibrations with the drawer I can't offer much help as I don't have a drawer on mine. Maybe the load is heavier and off balance slightly? Or maybe it is slightly unlevel to do the attachment of the drawer or a loose bolt or something. I do notice that mine does move slightly though and every once in a while I give it a little push back to straighten it out. Not sure that this really helps you....
Posted on Jan 12, 2008
geemarie
  • 876 Answers
SOURCE: Whirlpool Front Loader Washer Model# WFW9600
This code is not on the list.
Try this:
Push cancel twice
Select drain and spin
Select your cycle and push start.
If this does not clear the code, you will need a service call.
Before you do that I am wondering-Are you using an HE detergent and in small amounts? Are you loading the washer evenly- for example towels with towels lingerie with lingerie and jeans with jeans. Front loaders are very sensitive to how they are loaded. Check everything you can:
Turn off the washer and unplug it. Grab some old towels and a bucket.
Check the drain hose- is it twisted, squished or plugged ( you can turn off the washer unplug it and remove the drain hose to see if it is clogged.) While you are back there check the incoming water hoses are they twisted? Unscrew them from the washer and make sure the little filters at the ends of the hoses are not plugged, so that water is coming in freely. Make sure water valves are turned all the way on.
When you are back in front examine the door seal. Is it in good condition? Give the tub a spin with your hand. Does it spin freely and does it feel secure?
Check your dispensers. Are they clean and empty? if they are not try running an empty short cycle with just a little Hot water in the liquid dispensers to see if they are plugged.
Okay. Good luck to you. I hope this can be solved without a service call.
thank YOu for using FixYA Ratings are always appreciated.
Posted on Aug 24, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Posted on May 28, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
LF means long fill....if the flow meter does not detect
the correct amount of water entering the machine the
code will appear. Google Maytag front load washer
LF code...there are several links including a video
that should help you solve the problem.
Regards,
Dennis
Oct 05, 2014 | Maytag Washing Machines
My Maytag front loader washer gives an F H reading. Purchased in 2009, cannot locate owner's manual.
In the rear of the console inside is the diagnostic test sheets. They should tell you what error code means.
Jan 20, 2013 | Maytag Neptune MAH7500WH Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic front load washer spin cycle sounds like an airplane is taking off
If you mean a jet aircraft, that is normal. Front loaders achieve amazing spin rates.
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
530 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
