Question about Nokia N95 Cellular Phone
Battery charging problem
Hi. i dropped my n95 the other day. all is well but the phone only holds its charge for about 4 hours now. any suggestions would be appreciated. thanks
  • 74 Answers
If it have warranty replace it,
else make empty  then charge it.
ur's kishore chowdary.
+919441133420
Posted on May 18, 2008
What's your problem?i got a problem with the battery of my zte warp..how can i keep it charged at less one day?..it takes 2 hour to stay uncharged
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 09, 2012 | ZTE Warp
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
Duration of nokia n95 battery is 4 hours with or without use
try to refresh the battery by drainig the battery until it shutdown and then try to charge it for 12 hours. if the proble is the same after trying this. then you need to replaced the battery of your phone.
Aug 06, 2010 | Nokia N95 Cellular Phone
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Nokia n95 won't hold a charge
if you bought a new battery but it has made no difference so i think it may b something so you must repair yor mobile
Jul 17, 2009 | Nokia N95 Cellular Phone
Sudden Battery drainage - from full charge within 14 hours
turn off bluetooth if its on because bluetooth wastes battery life on any phone.
go to Tools > Settings > Personal > Display > and change the light settings. if its on the highest light setting then that would be a major factor on why your battery is draining quickly.
hold the menu button and check if any applications are still open, close any that you don't need open.
Apr 20, 2009 | Nokia N95 Smartphone
My phone nokia n95 losses its battery charge every 3-4 hours
Its time to replace the battery. Also check that the charger is working properly, and the contacts on both the phone and the charger are not oxidised. If they are, try scraping the contacts gently with a sharp object like a jeweller's screwdriver , etc..
Oct 25, 2008 | Nokia N95 Cellular Phone
Losses its battery charge within 3-4 hours
hi
you changes the batteries and reprogaraming the mobile in this whole mean while did you use the same charger if yes so you porably charge your mobile with the another one because you said the battery became hot is only becase of the voltage may be the charger capcitor lose their power to store the voltage so you just check the another charger.
thanks
your friend from fixya!
My N95 china deadset
hmm the best thing to do is go to the nearest cellphone shop re-pair
and ask them to reformat or re-program your phone....
here in Phillipines we can fix that prob. of clone china mobiles...
Feb 10, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Prashant  Sharma
Prashant Sharma
