Question about Kenmore HE2 Plus Front Load Washer
I ran a load & after switching the wash i noticed a puddle of water sitting at the bottom of the washer
  • 83 Answers
Water puddles usually indicate a leaking water pump-check the gaskets to make sure they are sealed before replacing the pump
Posted on Sep 17, 2010
Washer leaks in the spin mode
where are you noticing water is it alot of water or only a little the pumps are pretty known for going bad #3363394 pump usually small puddle dead front center of washer .... aswll as detergent dispensor hoses get plugged that drain into the wash tub
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking from the bottom
either the hoses are cut or the drum seal is bad
Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wash Machine smells bad
Gain access to the internal area (removal of cabinet panel) of the washer and inspect for source of smell.
Feb 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Small puddle of water from dryer?
you should check the back vent on your wall have you had any rain lately some times the strong rain will go down the back wall in the vent if broken
Jan 30, 2009 | GE WDSR2080D Top Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
Kenmore Elite Fronloader Water Problem
the water inlet solenoid valve has debris stuck inside of it, thereby not allowing complete "off" mode. best to remove it and clean the water path thoroughly. valve is found by tracing the inlet water hose.
Jun 03, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
150 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
