Furnace light blinks 3 times. Checked hoses, no apparent blockages. Jumped Pressure Switch, hot ignitor comes on but then quickly shuts off. No gas comes on, blower never fires up.
  • 69 Answers
Most likely the themo switch and or coupler is bad.
Posted on Sep 17, 2010
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
I have a Ducane MPGA100B4B gas furnace. The furnace only runs for about a minute then shut off. It does this far too frequent.\r\n First the induce draft blower turned on for a few seconds to check for...
Hello, sounds like the limit switch is opening on the furnace.Usually when a furnace goes off on its high limit is becuase the airflow is being restricted making the furnace overheat. a limit switch is there to protect the furnaace from overheating, most cuases are either dirt or the blower motor not running up to speed, anything that cuts down on the airflow will cause the high limt switch to open.
Feb 24, 2011 | Heating & Cooling
Turns on but no heat
From what I saw when I googled you furnace it has a hot surface igniter. It only gets hot when it's time to light the furnace. You should be able to see it glowing red when the furnace is trying to light. The furnace has a safety feature which shuts the gas valve when it doesn't detect a flame to prevent gas build up in the furnace. There are other safety features also. If the draft inducer motor isn't running the gas valve won't open. Overheat switches some of which have to be reset manually. Adjust the thermostat until it calls for heat then observe what is or isn't happening in the furnace. It will go thru a purge cycle first. The draft inducer motor will run to do this. After the purge the hot surface igniter should get hot a glow, then the gas valve will open and the burner will light. Let me know what you find.
May 04, 2010 | Goodman GMS90703BXA Heater
Goodman Furnace GKS9 pressure switch problem
Disconnect the small hose that goes from the pressure switch to the inducer motor housing, at the housing, and stick a paper clip in the tiny hole, and pull it up and down, and twist it. this small hole is probably dirty. good luck.
Feb 22, 2010 | Heating & Cooling
Three blinks on gas furnace, will not maintain flame
3 blinks indicates a pressure switch error. Check or replace air filter, condensate hoses for blockage, check small hose uo to pressure switch(s), check the vent pipes to make sure they pitch back to the furnace, check the air intake and exhaust pipes for any blockage outside. If all looks good, jump out pressure switch as soon as the exhaust fan starts to turn and see if unit starts. If it does, replace pressure switch.
Dec 01, 2009 | Goodman Heating & Cooling
Goodman GMP075-3 Has 1 single blink on the light
The blink codes are differant on every furnace. Read your code on the schematic found on the inside of the door. You most likey have a dirty flame sensor. Under the burners you should find a "single" wire going to a connector. This will be to the far left or right. Just opposite of a "two" white wires going to the hot surface igniter. Remove the 1/4 inch screw closet to the single wire under the burner. carefully pull out the flame sensor. Clean it with a small piece of sandpaper. Re install it. This should fix your furnace. KEEP IN MIND Goodman GMP models are noted for defective heatexchangers. Pull out the blower assembly and turn it over. If small rings about the size of a dime falls out.... this furnace is unsafe and should replaced!
Mar 08, 2009 | Goodman GMS90703BXA Heater
Furnace dont have heat
pressure switch stuck take off hose **** on it then put back on
Dec 21, 2008 | Amana PTC153B35AE Air Conditioner
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
