Question about Refrigerators
Hello Expert, Our Whirlpool Gold refrigerator model GB9SHDXPS01 is warm, but the freezer is just fine. Frost builds up on the back wall. I removed all the ice with a hair dryer, but about 6 days later, the ice builds up again. I understand that indicates that the defrost system is not working right. What should I do from there? Knowing that this problem occurs often, what is the most proba Any help would be appreciated, thanks in advance.
    President:
  • 834 Answers
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is actually that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism. The defrost heater coils can easily be checked by dis-connecting them and using an ohm meter, and a high or an infinite reading would indicate a faulty heater coil, however most of the time they are easily identified as being bad just by looking at them.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Hello Expert,
3da7540.jpHello Expert,
Our Whirlpool Gold refrigerator - aee74f1.jpg_mi
aee74f1.jpg Hello Expert, Our Whirlpool Gold refrigerator - e17f0b6.jpg /> 647e4f6.jpg
Posted on Sep 18, 2010
  • 17,130 Answers
You have come to identify the fault. The defrost timer is one which runs around a cycle to switch on the heaters so as the frost is taken off the coils.
The timer is normally located at the bottom rear of the fridge and the wires are connected from the heater and the relay circuit.
You must make a note of the connection wiring colours before removing the timer for purchasingg the same type.
Connect according to the note prepared.
It will be good to see if the Heater show continuity, the wires are not snapped in the frosting or a line connector make low contact with frost build up.Check this before the timer is bought.
Posted on Sep 17, 2010
  • Guy Cadieux Sep 17, 2010
    Caroldon,
    That was a fast answer : ). I just finished de-icing it. So ok, I will get to the heater and check continuity and contacts. However, looking at the drawings of this model, I don't find a timer. Is it possible that the heater is controlled by an electronic control card #AP4366538 ?
    Thx a lot again for your quick answering,
    Guy : )
  • Donald DCruz
    Donald DCruz Sep 17, 2010
    Yes , if the heater is connected to an electronic unit it is possible but in most cases it is a continuous timer which will not reset if power fails.
Model ET18NKXDW06. Water dripping from freezer down back of refrigarator. Placed bowl underneath opening to catch water. Should be going down to catch pan right???? Help Nell
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Hello, our freezer is working fine so far but the fridge is not.
The first thing you should be looking for is a frost or "snowy" build up on the back wall of the freezer. Assuming that there is a build up then you need to remove the back wall of the freezer. Gaining access to the defrost thermostat and defrost heater is a little difficult due to the frost build up. the defrost thermostat is attached to the evaporator coils to the right of the fan assembly. You need to check for continuity across the thermostat. The thermostat is the most likely cause.
Jan 11, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
Have a Whirlpool Gold fridge. Model #GB2SHDXTQ00. This week the fridge stopped working but the bottom freezer works fine. Is this just a thermostatic control issue? What part might be causing the problem? ...
Check the back wall of the freezer for frost . If there is then it is either the defrost heater, timer or thermostat. If there is no frost check to see if the fan in the freezer is running.
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Warm frig cold freezer
is the fan running in the freezer? most likely the evaporator coil is frozen over. is there frost build-up on back freezer wall. what is the model #? could be the defrost timer, heater element or the defrost terminator.
Oct 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
663 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
