Question about GE Spacemaker JVM1640SJ Microwave Oven
Unit indicates voltage but oven produces no heat
  • GE Master
  • 17,129 Answers
Might have to look for the series fuse to the magnetron, if blown and on replaccement if this blows again the magnetron is faulty and needs a replacement.
If this seems OK , the high voltage capacitor can be weak or open or short. replace and the microwave will work.
Finally check the door switch the temperatrue cut off unit , the main relay and the control board.
Posted on Sep 17, 2010
My ovens turns on but fails to produce hot wave
A microwave oven produces heat with the help magnetron which produces radiation. so the magnetron need to be replaced. try to contact your oven dealer! i do suggest to have a new microwave oven. because the magnetron is costlier you cannot repair it! Main cause of magnetron malfunction is, less use of microwave oven or less voltage.
Jan 14, 2011 | Kenmore Microwave Ovens
Everything is working, but no heat. lights come on, turntable turns, fans run, but no heat
Normally this would indicate that the diode in the power supply for the Magnetron (microwave radiation emitter) has failed. I would recommend that the unit be serviced by a professional in this area, or disposed of because of the following:
1 The power supply for Magnetron Tube the produces thousands of volts and can produce a lethal shock even though the machine is turned off and unplugged. Really, I'm not kidding.
2 Working on a Microwave Oven can expose you to high levels of Radiation which can immediately
Damage internal organs.
That said, there is another even better reason.
3 Microwave Ovens are now very inexpensive to replace.
Even though I personally know how to fix them, I can't be bothered.
I hope I have been of help
Happy New Year,
Best, Mark
Jan 01, 2011 | Samsung SMH9187 Microwave Oven
Unlock. unit will not heat anything
HI. Your symptoms are a strong indication of Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON.
Nov 21, 2010 | Amana Radarange Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
The microwave will not heat the food.Can it be fixed?
Jun 15, 2010 | Microwave Ovens
Oven not heating
HI. Your symptoms are a strong indication Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
Feb 15, 2010 | Sharp R-230 Microwave Oven
Microwave, adora, stopped heating
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Mar 14, 2009 | GE Adora DVM1850 Microwave Oven
HV Transformer and Maganatron
I would not recommend an inexperienced measuring secondary voltage on the high voltage transformer! The filament winding produces about 3VAC but the high voltage winding produces well over 2000VAC! And that can be instantly lethal!
I would only recommend measuring the resistance (in ohms) of the windings with power off and capacitor discharged.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
The part number listed by the distributor for the high voltage transformer is RTRN-A527WRE0 (zero on the end, not "oh") which is the same number shown in the service manual.
The two continuity checks on a magnetron are across the filament terminals, which should read about zero ohms, and from each terminal to the case, which should read open or infinity.
Even if a magnetron passes these continuity tests, it can still be bad.
Oct 04, 2008 | Sharp R-930AK Convection/Microwave Oven
PANASONIC MICROWAVE-NN-S615BFX
These H codes usually indicate a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic NN-MX26 Microwave Oven
Microwave oven not working model sharp R-38ST
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 07, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
