Question about Frigidaire FEQ1442ES Electric Dryer
Front load dryer frigidaire model FEQ1442CESO beeps for no apparent reason both during drying and for hours afterward. Lights flash on control panel randomly at the same time. Even hitting cancel does not work as it stops for about 30 seconds and then starts blinking and beeping again. Seems to dry fine otherwise.
I have the same problem... please help.
Posted on Oct 29, 2010
  • persian1 Dec 01, 2011
    Mine does the same thing...usually when there are clothes stacked on top, over the control panel. Sometimes moving the clothes will make it stop beeping and sometimes smacking it there will too. I think there is a bare wire somewhere coming from the contol panel that is coming in contact with top of the dryer and setting off the beep codes. They are never the same sequence of beeps and there is never anything else happening to cause a code, I.e. full lint trap, etc. Guess I will just have to take it apart and see-can't make it worse! Ill post back if I find a solution.
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
What is the appropriate fix for front load dryer that turns on and begins to run, but at any moment it stops, beeps over and over and lights all flash. The only way to stop the beeping/flashing is to
Thanks for the make and model of dryer. It is likely the thermistor is faulty. This tells the dryer how hot it is getting. If dryer is ok to start with (cold) and then starts doing strange things once it heats up, then this is what one would suspect. The control board problem would show up in strange ways including not being able to start the drying cycle. For location of thermistor see the drawing on this site. The model may not be exactly same as yours but gives an idea.
Items 33 and 36 in diagram 1. Frigidaire Washer LEQ2152EE1 Parts List
Sep 10, 2014 | Dryers
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
Touch Panel Control Shorting Keys
I would check out the UK WHICH website.
Aug 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire front loaded dryer that is just a few years old. It continually beeps and the lights on the front panel flash and after few minutes it shuts off. How do I fix this problem?
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
chris.polk@electrolux.com
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Aug 26, 2012 | Frigidaire Electric Dryer
I have a frigidaire gallery series front loading electric dryer model # 134509400c.press start and it beeps with a dr code.any idea what is causing this?
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay this is not a factory taught test.its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Oct 22, 2011 | Frigidaire Electric Dryer
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Just had an Affinity front loading washer delivered today. Did four loads without any issues, clothes are clean and smell great. After the washer was idle for about an hour, it started beeping, and the...
try disconnecting the power for at least 30 seconds which might reset control if this fails call service the control is faulty you have a 1 year full warrenty
Dec 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FEQ1442ES Electric Dryer Logo
2,190 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
