FixYa.com
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Fan motor slow on a/c
posted by jonnieac on May 17, 2008
The fan motor on my window air conditioner starts out at what seems to be about the right speed for high but varies and slows with time. It does not matter whether the compressor is running or not as whether the fan slows. The fan motor gets hot however the wires leading to the motor do not get warm.
Comment by jonnieac, posted on May 23, 2008
THe motor is drawing the correct amps. The a/c unit has only about 5 months use on it. The motor becomes too hot to touch but does not draw any more amps. The bearings are very smooth.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 18, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
Rating Locked! (?) jonnieac has rated this solution as Helpful
This Problem Also Relates To: GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit Air Conditioner GE (AJCQ08ACB) Air Conditioner GE APN10AA Portable Air Conditioner GE Deluxe AGM12AB Air Conditioner Panasonic 9,800 Btu Room Air Conditioner with Touch Controls and Remote Control, CWXC104HU Panasonic CW-C60RU Air Conditioner DeLonghi PAC C100 Air Conditioner
Can you Help with these Air Conditioners problems?
Air Conditioners
Through the wall airtemp air...
Air conditioner is blowing air... Answer This...
Air Conditioners
Coleman outdoor air cond. unit
Coleman outdoor air cond. unit... Answer This...
Air Conditioners
won't cool
won't cool Answer This...
Air Conditioners
I need wireing schematics for
I need wireing schematics for... Answer This...
Air Conditioners
Gas Furnace locks down in
Gas Furnace locks down in half... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
