Error 0271 : check date and time settings fan error how to fix this 2 error on IBM think pad 2647-2 TU, it display when turn on the power. thanks alot
  • 398 Answers
Easy way is to run the setup utility and clear the date and time - else go into BIOS and change the date and time to the correct ones. If it keeps reverting then you need to put a new battery in.
Posted on Sep 17, 2010
IBM T30 error 0271
Error 0271 means: Date and time error. Neither the date nor the time is set in the computer. You need to set the date / time in the BIOS.
Jan 02, 2012 | IBM Computers & Internet
Need password for entering windows. there is error 0271: check time and date setting. my friend said that the motherboard error, must be reset or change... what should i do???
I have the same problem with a desktop.
To bypass the error, You might need to set the correct date and time every time you power up your laptop. Date and clock setting can be set via CMOS configuration.
Jun 13, 2011 | IBM ThinkPad T23 2647 Notebook
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
ERROR CODE 0271 ON IBM R51 LAPTOP
your cmos battery is not working replace it
Aug 31, 2009 | Computers & Internet
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Jul 17, 2008 | IBM ThinkPad T21 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
645 people viewed this question
David Payne
David Payne
