Question about Vtech Cordless 6041 Phone
How can i block calls using my vtech dect6.0 - Vtech Cordless 6041 Phone
How do I unblock a number on my vtech cordless phone
Press VOLUME? until you see Calls w/o num, then press MENU/SELECT. Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support/product/3394
Apr 19, 2018 | Vtech Lands Phones
How to unblock a Vtech cordless phone with blocked caller the model number is:CS6919
With the handset in standby mode, press Menu (on the right below the LCD screen). Use the Up/Down arrows to navigate to Call Block. Press Select (the same as Menu). Navigate with the Up/Down arrows to highlight the line Block List and press Select again. Navigate to the line Review with the Up/Down arrows and press Select. Use the Up/Down arrows to navigate to the blocked number that you wish to delete. Press the Mute/Delete button (the center button below 0). You should hear a confirmation tone and either the next number in the block list or list empty should appear on the LCD screen. (You can't delete the entire list at once.)
The procedure to delete a blocked item in the Call Block list is given on page 21 of the full manual. The manual is available from VTech on the product page: https://www.vtechphones.com/store/pd/3370/CS6919-Cordless-Phone-with-Caller-ID-Call-Waiting . The direct link to the manual is https://cdn-media.vtechphones.com/products/CS/CS6919/CS6919-X_WEBCIB_V4_20160224.pdf .
I hope this helps.
Sep 12, 2017 | Vtech Lands Phones
My call block is full. How do I remove a number?
Try Googling (Vtech)(CS6929)(manual) without parens to get information.
Aug 14, 2017 | Vtech Lands Phones
We have a robo call two times a day - can I block the number? On a Vtech CS5111 phone
The only way to block calls is through your phone service to the house, not on the phone. Call your provider and see if you have call blocking. If not you will need to add that service. Usually for a few dollars a month.
Dec 29, 2016 | Vtech Lands Phones
How do you block a house phone
there is no way that I am aware of .
Jul 05, 2016 | Vtech Lands Phones
How do I block a number on a vtech cs6719-2 cordless phone
It all depends on your service provider, (e.g. comcast, at&t, etc.) this webpage should help you find out how to do it with whatever provider you have:
How Blocking Incoming Calls Works
Feb 02, 2016 | Vtech Lands Phones
I need to block a couple callers from calling whats the number to block # what
Call youre service provider and then you can block all outgoing calls with a code they give you. to unblock phone pick up phone put code in and make youre call.
Jan 19, 2015 | Vtech Lands Phones
How to block calls on home phone that show up as private caller
You would have to subscribe to that feature from your local phone company, then when a number like that calls they will get a recording that states you do not accept blocked calls...
Jun 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do you block numbers
Most of the telecom service providers offer call blocking features. In addition to this, most of the vtech cordless phone sets have built-in features through which you can block incoming calls from a specific number.
    • Create a "Call Block List" on the vtech phone and store the Caller ID information of unwanted callers in the list. The numbers you feed in the block list will get a busy signal every time they try to call you.
    • Ring up the customer service of the telecom company that is providing you the phone service. Tell the representative that you want to get your incoming calls blocked from a specific number. The company will then add that number to a list of blocked numbers for your particular phone number. In the future, every time an unwanted caller tries to ring you up, he will hear a recording saying the number has been blocked.
    • Visit the website donotcall.gov. Add your phone number to the website's list of phone numbers that cannot be reached by telemarketers and businesses.
Jun 12, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech Cordless 6041 Phone Logo
3,557 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
