Question about Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
The handle falls off and the screws sent by the company will not tighten
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Wrap a small amount of plumber's teflon tape around the screw before you install it. This should take up the gap in the threads. Do not use glue or thread sealant, you can permanently lock the parts together. The small plastic parts tend to strip out fairly easy. If this does not help, contact Grohe and ask for a complete rebuilt kit or new faucet. All these parts should be free.
Posted on Sep 17, 2010
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Range master 110 loose oven door handle
remove door from oven lay on flat surface and remove the screws around the outer edge CAUTION glass will fall out and break if not careful tighten the screws /bolts holding handle and reassemble it .
Jul 15, 2016 | Kitchen Ranges
Cannot secure the handle on my left/right handle,falls out cannot see
all I know of screw in from either direction . and you might not be tightening it up when inserting it .
Jun 27, 2016 | Sport & Outdoor - Others
The handle of my vacuum came off and the screw does not tighten anymore. Can it be fix?
I would try a larger screw.If it is a machine screw a Sheet metal screw may work in a slightly large thread.
Jul 12, 2015 | Dirt Devil UD20010 Extreme Cyclonic Quick...
How do I tighten the screws on the freezer handle?
Its hard to tighten it to how it was earlier. The company tightens it first and then forms the outer layer of the handle. You can't tighten it yourself without piercing those handle bars. If you want it to be how it was before, contact the company. Else do it yourself.
Apr 22, 2010 | Viking VCBF036LSS Stainless Steel
How do i tighten my door handles on my kitchenaid superba refrigerator. It has small screws on the handle but they dont tighten??
the small screws are for the covers.remove them covers will fall off showing handle screws use loctite to secure so they dont work loose.....
Feb 06, 2010 | Refrigerators
The handle on my kitchen faucet falls down and
There should be an Allen screw on the underside of the handle. Loosen it to take the handle off, then tighten up the packing nut with a channel-lock wrench.
Sep 13, 2009 | Plumbing
The Danco Universal Faucet replacement handle Model 46004 has sufficient play so that after a few turn on / turn off cycles, the center screw backs off and becomes loose to the point that the handle may...
Get some Lock-tight formula to apply to the screw. Let it dry a few minutes after application. Naturally, after application of the solution, you have tightened the screw to its maximum. Do not be concerned about ever removing the screw as the material will loosens when you apply manual force.
Feb 07, 2018 | Danco Clear Faucet Decorator Handles
Refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
Jun 12, 2009 | Refrigerators
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
130 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
