Question about Air Tools & Compressors
My 60 gal comp. has an emerson motor,model #t63xwbss1486. today it blew one of the two devices attached on the top of the motor.#CSC A CONBUSTIBLE FLUID.i need a replacement .
2 Suggested Answers
SOURCE: emerson T63XWBSS1486 motor the capacitors
http://www.five-two-one.com/installation.htm
http://igor.chudov.com/manuals/ElectricMotors.pdf
http://www.control.com/thread/1026162306
http://stearns.rexnord.com/pdf/Cat_902/26-27.pdf
Hi have a look at these posts above i am sure they will help a picture is worth a thousand words they say...
Posted on Jun 25, 2011
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
How do I wire my 60 gal 3 hp IR commpressor? What size wire, what size breakers, and where on the motor do I attach my wires. Motor says 15 amp, 220 volt. Thanks, Clint
I would use a # 10 wire size with a 30 amp breaker. The motor should already wired to the pressure switch unless it has a mag starter. If no mag starter incoming power should go to pressure switch not motor. If unit has a mag starter incoming power should go to top of mag starter.
Jan 12, 2011 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I am missing the screw in drain plug for a Model 95386 air comp.
this is normal item at parts house, anyway why do have a plug. i put a small ball valve much better i got at home depot
Jul 02, 2009 | Air Tools & Compressors
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Csc, sec functions
I have not yet seen a calculator that has a dedicated key for the cosecant , secant, nor cotangente functions, because they are directly connected with the sine, the cosine, and the tangente.
Cosecant (x) = 1/sin(x)
Secant (x) = 1/cos(x)
Cotangente(x) = 1/tan(x)
Do not confuse these functions with the inverse trigonometric functions, usually represented as
arccosine = arccos; on calculators cos^-1,
arcsine = arcsin ; on calculators sin^-1
arctangent= arctan ; on aclculators tan^-1
Hope it helps.
Feb 08, 2008 | Casio FX-115W Plus Calculator
Air Tools & Compressors Logo
1,401 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
