Question about Frigidaire GLWS1233A Top Load Washer
Frigidaire GLWS1233A Top Load Washer is leaking from the bottom, there are no kinks in the hose, water is coming from the bottom.
  • 1,531 Answers
There is a chance that the tub seal is broken. in orfer to check it you need to remove the front panel by taking the two screws out of the bottom the push the two clips in that are located about an inch in from either side of the washer the lid will pop up and then you can remove the front panel.
then start the washer again and look to see where the water is coming from
Posted on Sep 17, 2010
Water continues to run into washer even when i shut of the dial
Your inlet water valve is bad. That is the part where the hot and cold hoses hook to the washer.
Jun 16, 2011 | Frigidaire GLWS1233A Top Load Washer
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
Cold water fills too slow. Hot OK. Hose/faucet OK. Is there a fliter/screen? Where?
remove hose from washer and you will find the screen. Get something like an ice pick and hook it to remove and clean.
May 10, 2010 | Frigidaire GLWS1233A Top Load Washer
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire gallery
The choices are: cold hose kinked, water supply valve closed too far, cold water solenoid stuck or bad or clogged.
Mar 28, 2008 | Frigidaire GLWS1233A Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Overflowing and smell
needs a new pressure switch located in control panel are the small rubber hose going from the switch to the tub has a pin hole in it
Nov 29, 2007 | Frigidaire GLWS1233A Top Load Washer
HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
Sep 04, 2007 | Frigidaire GLWS1233A Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
289 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
