Question about Samsung WF328AA Front Load Washer
When i try to start my washer it beeps and flashes d5 what does this mean?
  • 83 Answers
Refer to your owners manual-it will tell you what all of the messeges mean
Posted on Sep 17, 2010
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
What is the sequence to get code to find out washer malfunction?
Press both the start and pause buttons together and count the beeps. Then the light above the start button will flash so count those. Example is 5 beeps and 9 flashes means error code E 5-9
Jun 29, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
Jul 12, 2010 | Samsung WF337AA Front Load Washer
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wont start
Try unplugging the unit for an hour allowing the microprocessor to reset. Plug it back in and use as normal. Let me know if this helps.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Beeps and flashes
it may be that the pressure system is blocked, and the machine is therefore not going to fill. try checking the press system for a blockage.
Jun 13, 2007 | Zanussi F1045W Front Load Washer
Samsung WF328AA Front Load Washer Logo
214 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
