Question about Frigidaire ATF6000ES Front Load Washer
E 70 error
I have ATF6000ES washer, every time I use - 12-15 min prior finish I get a error message E70. I can not find any solution for this problem
  • 868 Answers
You need to make sure all of wire harness connectors are firmly making contact.This is a loose connector issue.You can fix this if you have patience.You need to start by removing the front panel and starting with the main control board,located on right side at the bottom.Remove the plug in connectors 1 by 1 crimping down the point where the contact is made.Picture this, there is most likely just ONE wire that isn't making a positive touch,and you have to find it.Easy way is after you have checked the control board and tightened the connections,re-check the machine .
Posted on May 22, 2008
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
What dose E70 mean
Means if it is Kenmore that the cold water is not entering the machine. Try removing the washer hoses from the shut off valves after shutting them off of course. and check the little metal screens on the back of each hose connection check for dirt inside Hot and cold.
Apr 05, 2012 | Frigidaire ATF6000ES Front Load Washer
E70 Error Code- will wash for 1/2 of the allotted time - code appears-machine stops. Tech was here today and said I needed a new water valve (cold)- also ran 3 loads on normal with no clothes and the...
Hello, it is a cold water issue either the water is off the screens on the valve where you connect the hose is dirty the hoses are reversed or bent and last the cold water valve failed.Its one of these. Hope this helps please rate my answer Thanks :)
Jun 08, 2011 | Frigidaire ATF6000ES Front Load Washer
What does error message E70 mean?
Remove the top panel and theirs a tech sheet that will tell you what the code mean
Dec 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Stops within cycle E70 is error message
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
E70
HI, this is a major control board fault code. the chip set on this board is damaged. it cannot be repair and, it is recommended to replace the entire control board(main) in this case.
A service call is recommended.
Jun 17, 2009 | Frigidaire ATF6000ES Front Load Washer
The washer is leaving a dark stain on all of my white clothes
the dark stains are caused by mold build up on the boot of the washer, the e70 may be a pump error. you need to wet a cloth with bleach and then wipe of the mold builldup on the boot, this should solve that problem.
Jun 14, 2009 | Frigidaire ATF6000ES Front Load Washer
E70 message halfway through wash load ???
It means you aren't getting cold water into your washer.It may be your hot & cold water hoses are backwards.Or check the screens in the valve and hoses make sure your cold is coming in .
Please rate this !!
Mar 20, 2008 | Frigidaire ATF6000ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
