Question about Kenmore 85871 Electric Dryer
Kenmore HE2 desn't stay running and F22 errror shows
  • 83 Answers
Refer to the owners manual to learn what these error messeges mean
Posted on Sep 17, 2010
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
Washer flashing F22 and dooris locked and will not open. How do you unlock the door to reove the clothes?
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
Sample tech sheet for HE frontloada
Get your tech sheet by removing your bottom panel or posting your model number here
Duet manual and more here
Sep 10, 2010 | Kenmore HE2 Plus Front Load Washer
I have a he2 kenmore front end loader washing machine...it stops mid load and flashes F20
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
Error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
I am receiving error codes on my HE 2 plus front loading washer. F33, F22. and it won't get past the 1st cycle. Is the problem the CUC. or is there a quick fix to this problem.
i found this site thought you may find some help here but there seems to be a lot of peeved off people when it comes to this brand lol
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~6621/forum_id_~409
Jun 13, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he2 plus washer is showing f21
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you. If you require further assistance, please let me know.
Aug 16, 2008 | Washing Machines
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
May 05, 2008 | Kenmore 82836 Gas Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Kenmore 85871 Electric Dryer Logo
174 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
