Question about Rowenta Professional Luxe DM880 Iron
The iron will not steam when button is depressed. model #DE-87
  • 10,865 Answers
Hello. Begin by cleaning the iron as follows: Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
Cleaning the Soleplate
Unfortunately, the soleplate of an iron is prone to occasional build up. Therefore, the soleplate requires cleaning in order to avoid staining the clothes or fabrics. Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
Posted on Sep 17, 2010
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Steam button broke?
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
May 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
How do you reset the water filter light when you put in new filter on Breville Steam Generator please
Ok, had this too. Done some research and it looks like you have to unplug the iron from the mains , keep both the power and steam level buttons depressed and then plug in and switch on.
Chris.
Feb 12, 2011 | Breville Irons
No steam coming out of iron
Have you used a self clean function? If not then hold the iron (switched on and heated up) over a kitchen sink and depress the 'power steam' or equivalent button several times.
If that does not clear it you will need to dismantle the iron to clear any blockage.
Mar 30, 2010 | Irons
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Steam Button Sticks in
vinegar the iron its calcified,it will clean out
Sep 30, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Aug 24, 2008 | Rowenta Surfline Iron DE-333 Iron
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Rowenta Professional Luxe DM880 Iron Logo
287 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
