Question about Bosch WFVC6450UC Front Load Stacked Washer / Dryer
I have a Bosch washer model# WFVC6450UC One of
I have a Bosch washer model# WFVC6450UC One of the listed "features" for this machine is "Drum Sanitize heats water up to 175F to clean the drum" (Ref the Bosch website listing the features of this machine) However, the owners manual does not mention how to actually USE this feature. In fact, the manual is silent about it altogether. Can you please explain how I can turn on this feature to sanitize the drum with 175 degree water?
  • 1294 Answers
SOURCE: Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Posted on Jan 05, 2008
  • 135 Answers
SOURCE: our model is a bosch maxx plus 5years old front loader
Is it water in the tub that you can see?
Posted on Jul 28, 2008
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
  • 240 Answers
SOURCE: Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Posted on Apr 27, 2009
  • 14 Answers
SOURCE: drum still has water in it once the cycle has finished.
try cleaning firter or pump might be blocked .
Posted on Jul 07, 2009
How to access door switch?
You are on the right track but you will probably have to remove a panel to access the switch for replacement. Look for a way to get in and .......................
Aug 31, 2015 | Bosch WFVC6450UC Front Load Stacked Washer...
I'm getting an E:17 error code on my washer when I try to start it. In January of 2012, eMCee2 provided an answer that apparently worked to someone else with this problem.problem. Problem is, I can't...
You have a leak
it is collecting in a tray under ther washer
the tray has a float switch in it
when the tray fills up the float switch activates telling the computer it has a leak ERROR CODE F17
by tipping the washer backward you drain the water in the tray and reset the switch
this will only be a short term fix because you still have a leak somewhere
Mar 29, 2015 | Bosch Vision Series WFVC6450UC
Bosch Nexxt 6400 has flopping drum-can move it back and forth while spinning by hand. Tech sez broken shaft gear--get rid of it.
this has had its day mate get rid of the machine as you can not repair as the drum is sealed on that model ok
Nov 03, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch WFVC6450UC Front Load Stacked Washer / Dryer Logo
169 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
