Question about Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
How do i remove the bit from the drill - Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
  • 3 Answers
This drill has a 2-level chuck handle. one is slightly larger diameter, or is closer to drill body. It is fixed to the motor shaft. Smaller diameter, or forward one is the adjustment. Hold the rear/larger one stationary and twist the smaller/forward one as if you were opening a water bottle with a really tight lid.
Posted on Sep 17, 2010
3 Suggested Answers
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
  • 18 Answers
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Posted on Jul 09, 2009
How to fix remove part of Brocken round file out of cylinder head What type drill bit to drill down the centre of round file 3.5mm x 112. The file is 5mm across
That file is incredibly hard, harder than your drill bits which will wander off and drill the cylinder head itself.
Can you remove it from the other side?
Aug 06, 2016 | Drills
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
How to change drill
If you asking about the bit usually trap two hands around the head of drill where the bit goes in and twist hands in opposite directions to loosen, you will see a centre grasp of two or three which is where you drop the drill bit into or remove from. Do either of these add or remove then tighten the same way you removed. Make sure the drill bit is centre and straight and well seated within the grasps when tightening back up.
Jun 04, 2012 | Drills
I having problem of drill bit would like to know how to remove drill bit
Make sure the chuck is loose then clamp the drill bit in the vice and give the drill a straight pull ,once its out then put some engine oil down the chuck and let it soak in ,not that fish oil spray stuff .
Dec 02, 2011 | Metabo 600661620 SBE660 12" 01000 03000...
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
I can't get the the drill bit out of my cordless drill
Try to keep your drill straight and try a bit harder - looks like you were drilling something very heavy.
Apr 03, 2010 | Dewalt 18 Volt Compact Drill Kit
Cannot remove drill bit from self locking chock
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
Nov 09, 2009 | Drills
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
147 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
