Question about Westinghouse LTV-27w7 7 in. LCD HDTV
I lost my tv power supply cord my tv is 110-240 can I use a 10a 125V cord from my computer that fits in my tv (to replace the one I cant find)?
  • 456 Answers
In my opinion you can use the same cord, I use the same cord for my spare Xbox360, TV, workshop PC as well as my guitar amplifier.
Posted on Sep 17, 2010
  • Westinghouse Master
  • 8,457 Answers
No,tries websites like Partstore.com,Amazon.com,Ebay.com to buy the right power cord.They're different cords tv power cord 110-240 voltages.The computer a/c power cord 10 Amp to 125 voltages.Don't try it,will burn somethings on the tv.
What power cord can I use for my TV?
Not 100% sure but I have swapped cables from pc, tv, and monitor freely between them all to get right length of cable for each device and I have had no problem with any of them.
If you want to be safe start with the lowest power out put cable and work up, that said have just checked several that I am not using and they all appear to be the same output
Mar 04, 2016 | Televison & Video
Power cord for Janome MC11000 sewing machine
You need to require parts from Janome, Contact them here
Jul 18, 2008 | kawasaki PVS1080
Replace power supply
Be sure to look on back of tower to see what power you need. The power plug needs to be 115v or 125v on most. Be sure your cord is the same voltage.
Nov 15, 2012 | eMachines Acer Emachine EL1358G-51w 2.8GHz...
Apex ld3249 what ac. Power cord do I need 10a 125v or 7a 125v
Hello
The power in cords have no specification and it is not a critical component to any device. Just buy one power cord, whicn meets your need. Get it from a reputed electronic spare part selling shops at your town. Keep the present power cord in hand as a sample, when you go for new one. Most of the present power cords will meet your need.
http://www.dataentryjobs.us/67948.html
en.wikipedia.org/wiki/Power_cord
Feb 01, 2012 | Televison & Video
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
I need a power supply cord for my westinghouse roaster oven - Cat. Nero 5411-1, 120 V, 1400 W. However, the numbers on the cord itself are 15A, 125V, 1575W. It is very old, but still has a paper sticker on...
I wish all cords fit all cook pots, wouldn't be grand. But they don;t an they often get lost and miss guided. I would try looking at Thrift stores and Salvation Army stores , they have a lot of missed matched cord,cables I found one most recently for a fry pan for a friend of mine.they are very common ,only .50 cents. Happy hunting DFD
Apr 13, 2009 | Crock Pots & Slow Cookers
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
394 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
