Question about Gateway M-6750 Notebook
How to fix a broken key bored - Gateway M-6750 Notebook
  • 388 Answers
You need to buy another one or use an external keyboard. Also try a key remapping program like keytweak if you've just a few keys busted.
Posted on Sep 17, 2010
My machine is not turning on
Fixing the Coffee Maker - YouTube
? 10:44
https://www.youtube.com/watch?v=kcofrC4vvDw
Nov 2, 2011 - Uploaded by CornfieldCraziness
Mine short circuits the power-bored outside as soon as I turn it on ... How to FIX a Bunn coffee maker that ...
Broken Coffee Maker - YouTube
? 1:15
https://www.youtube.com/watch?v=HzyeCdSjOPU
Dec 12, 2013 - Uploaded by Heilman Hackatronics
Attempted to repair a coffee maker. ... Fix Your Broken KeurigCoffee Maker - New tips and tricks - Water ...
Mr.Coffee maker stopped working - Home Improve
Dec 03, 2015 | Coffee Makers & Espresso Machines
I got a 1983 xr80. What are the piston/cylinder clearance specs.. stock? And how much can I hone/bore out?
most piston /ring kits come in .010" , .020",.030",.040" oversize
most engine re-conditioners use cnc borers set to an over size and bore to that
after honing to get the correct cross hatch pattern in the bore , that is it
the ring gap is what is important and it should be around .003" per ever 1" of bore
so for a 3" bore the gap should be around .010"
experience has proved that if the cylinder is bored to say .020" oversize then when the gap for .020" oversize rings is checked ,it generally comes in around .015 and even as large as .020"
max specs for ring gaps is .025" which is for a worn cylinder
just honing a bore is a waste of effort as bores wear in a taper ( larger at the top than the bottom and this taper increases the wear of the new rings and can lead to broken rings
the ridge at the top of the bore has to be removed to allow the piston to come out easily and to prevent piston failure when the new rings are fitted
have a talk with engine reconditioning shops and then make an informed decision
remember that if the cylinder can be separated from the crankcase , you can buy standard or oversize piston/ring/cylinder sets as assemblies so there is no need to bore out or hone.
Sep 03, 2015 | Motorcycles
While driving the engine abruptly stalled and now engine will not even turn over
What kind of car? Did it overheat severely? Possible timing belt broken and jammed up/bent valves restricting engine movement
Apr 12, 2015 | Cars & Trucks
My 200R Honda piston is broken and also d rings need some help finding the parts
If the piston and rings broke, you cylinder bore is probably wasted, and needs an over bore.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-bike-parts/o/m3049sch304631
Piston is item # 3 = $76.15
Rings are item #2 = $42.54
Also, DO NOT reuse the piston wrist pin retaining clip!!!
Item #14 = $0.83 each (2 required)
Oct 23, 2013 | 2002 Honda XR 200
1996pontiac sunfire2.4motor no compression number 2 cylnder
more than likely is a burnt./bent valve. I would remove the head as sometimes the seat insert becomes loose and results in head work to fix. No compression can also mean broken rings or scored bore so the head will have to come off to determine exactly what happened .
Jul 22, 2013 | 1996 Pontiac Sunfire
I have a redhead pursuit bore sighter when i try to bore sight my grand sons 22 it does non seat very tight when you attach it to the bore just a slight movement it does a 360
I have the same bore sighter and to fix your problem is easy. Wrap some TEFLON TTAPE (plumbers tape), it'll tighten it. Hope it solves your problem.
Sep 23, 2011 | Sport & Outdoor - Others
I need win 7 driver for air touch flexible keyboard. thanks david
Honestly the driver you need actually depends on the brand of your key bored. Like what company makes it. The best way to figure that out is to just look on the key bored whats the brand name?
Simply try going to that company's website. If you still are having trouble just leave me the company name, model # of the key bored and I will do my best to help you find it. Also if they key bored came with a install cd it should be on that as well.
Sep 26, 2010 | Computers & Internet
Not starting
piston weight is critical to how the engine works &runs that peice thats missing helps hold the piston square in the cylnder bore the broken piston needs to be replaced
Dec 31, 2008 | 2008 Motorhispania MH-7 Naked
Cleaning the key bored
pop down to pc world and buy anew one is what i would do but for the time being if windows xp go on start menu go to accesability and select on screen key bored.
May 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gateway M-6750 Notebook Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
