Question about Jensen Car Audio & Video
I need a wiring diagram for a jensen car stereo
  • 2336 Answers
SOURCE: car stereo wiring diagram
Check this website on how to install them.
Good Luck.
Posted on May 04, 2008
shaggyrat
  • 1224 Answers
Main power wires
Yellow to constant always on power
red to accessories
black to ground
blue if you have an amp this will be remote wire if you dont have amp then just cap off
the other wires are as follows
top section speaker wires right and left
bottom section speaker wires right and left
the speaker wires come in colors like purple purple line
grey grey line
orange orange line
white white blueline
these are your speaker wires simple just remember power lines grounds
Posted on May 07, 2008
SOURCE: WIRING DIAGRAM FOR 1988 TOYOTA PICKUP CAR STEREO
just use a volt meter and test around to find your powers and grounds. then look behind the speakers to find the wire colors and compare to behind the stereo
Posted on May 26, 2008
  • 22 Answers
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
Posted on Mar 10, 2009
  • 166 Answers
SOURCE: Need Wiring Diagram for a Pioneer MOSFET 50 Wx4
Found the manual on Crutchfield's site
The wiring diagram is on Page 25
Posted on Jan 23, 2010
Does the Jensen UV 10 stereo have internal fuses that can be replaced
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jan 15, 2017 | Jensen Car Audio & Video
I need to know where the ground wire goes in the pinout connector for jensen mp5610
All car stereo's are internaly grounded, so just connect the ground wire to the stereo chasis.
Jul 12, 2011 | Jensen MP5610 CD Player
I have no harness labeling ground, hot or speaker wires, I need diagram
Alot of new stereos have an ISO color code,
This is mine:
Car Radio Constant 12v+ Wire: White/Green
Car Radio Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Apr 25, 2011 | Jensen Car Audio & Video
Hooking up an amp
you need rca cables, an amp kit from your local audio shop(or walmart). make sure you know which wire is the remote from your radio as it will need to connect to the remote on your amp. most radios have the wiring diagram on top of the radio. Ground(black)/Power(from battery) and remote(typically blue from stereo.
Apr 01, 2010 | Jensen's VM9312 Car DVD Player
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
May 02, 2008 | Jensen XA92 Car Audio Amplifier
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Car Audio & Video Logo
102 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
