Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
  • 456 Answers
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Posted on Sep 17, 2010
Tv won't turn on. Timer light fast blinking
either wait until the light stops flashing or press the reset button. if teh problem persist it is most likel several boards that need to be rplaced
Feb 22, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
Green timer light blinks constantly
you can get the V26 DLP DM repair kit at the following link which should repair that isue. The kit contains the capacitors and the CD with instructions.
http://www.tvrepairworld.com/
Jul 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
The timer light won't stop blinking - the tv wont go on at all -- I have unplugged it for a week and then tried plugging back in and it just blinks. I have tried the reset nothing will make it stop...
You need the V26 Chassis DLP DM repair kit available at the following link. The kit contains the replacement capacitors and CD with full instructions on how to do the repair .Its listed under the mitsubishi repair kits category
Jul 12, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Tv won't power on
I trashed the set and bought a new one.
Jul 02, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
386 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
