Question about Kenmore Kitchen Ranges
My kenmore electric range model C970-656932 is acting up. Although the stove top works the oven does not come on The clock and buttons that operate the oven and clock seem to be "dead"
  • 140 Answers
SOURCE: no electronic oven control guide for oven settings.
hello, here is the link to your manual.ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200445en.pdf
and here is the link to the controls ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200167.pdf.
Don't worry about it saying electrolux. They make some of the Kenmore appliances. Hope this takes care of you and don't forget to rate me. Thanks.
Posted on Jan 03, 2009
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
  • 1073 Answers
SOURCE: oven burnout
Posted on Apr 25, 2008
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My oven and stove top doesn't work
Being that I am not familiar with this particular oven/range, I can only make a suggestion. But the clock most likely runs on a different circuit, since it requires much less power to operate than do the oven and range. The heating elements are linked together, so if you have a short in a wire, or a switch that has gone bad, it could affect the entire heating system, if it was in the proper place. The best way to check would be to open the top and rear panels and inspect the wires and look for any damage. Also look for a fuse or something that may be blown. Before you do any of that, please disconnect the power from the unit. It is no fun getting shocked!
Dec 16, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
210 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
