Question about OKI C5510 MFP All-In-One Led Printer
Printer is saying it is printing but it is showing it has printer error. What should l do to get it fixed?
  • OKI Master
  • 17,130 Answers
Let us first assume that it was working fine till this fault occured.The ink cartridges werre not replaced or removed, the mechanism was not touched when the set was on.
If so remove printer , uninstall and reinstall the printer software, then connect the printer to be detected and installed.
Make a test print.
If there are errors present , it can be due to a mechanical fault or the mother board.
'Checck if the roller are moving ffreely, checck if the ink /head unit is free and not struck up, check the Power supply (SMPS) for any voltage errors.
If not the main board can be faulty
Posted on Sep 17, 2010
  • 298 Answers
SOURCE: "Printer Cartrige Error" message and "Check Printer Cartridge" light
Usually means out of ink
Posted on Nov 22, 2007
Nikhil Gedam
  • 87 Answers
SOURCE: Why is my printer showing a idle status and not printing?
I believe the printer is connected via USB.
Check in device manager if the LJ 1020 printer is listed.
If yes, go to the driver properties > ports tab and Select the appropriate port for the printer
Alternatively, uninstall the full software and reinstall it again from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439320&
- Nikhil
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: I have a Samsung that say Transfer Belt Error
hi guys.. iam Aqeel from pakistan.
i've just solved that stucking problem today and tellining u guys who are facing such problems over thr.
All you need to do are two steps:
1- detach the paper tray and push it back correctly.
2- open front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and left side of toner unit thr is a sensor door, behind that door there is also a light sensor bulb, which needs cleaning by a cotton bud.
thats all
i hope this will help u fixing that problem.
bbyee
Posted on Jan 20, 2009
yooperbud
  • 8637 Answers
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: canon ip1880 printer service error 5202
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Posted on Feb 20, 2009
Cure for: "49.4c02 service error"
This can normally be fixed by upgrading your print driver to the newest version. You can find print drivers at this link http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=412131&swLangOid=8&swEnvOid=54
Good luck
May 22, 2015 | HP LaserJet Office Equipment & Supplies
My canon ip1000 printer show error "print head not available". but head already fix in place
The print head may not be proper electrical connection. Remove the print head and clean the electrical contacts on the ink cartridge and in the printer with methylated spirits, replace the print head and hopefully this will fix the problem.
Feb 02, 2013 | Canon PIXMA iP1000
Just put all new image drums and toner in my Okidata C5300n, checked the IP address, the computer sees it and shows the pending print job, but the printer in not receiving the print job. I have tried...
In most laser printers, when you replace the drum, you need to reset your drum in your printer's menu options. This is to reset the page count for your printer to tell you when it will need to be replace again.
May 09, 2012 | OKI C5300n Led Printer
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
On my laptop i print something then it says its printing but then when i look at my printer nothings printing it. My laptop says its go an error but i need to know how to fix it immediately.
you may ned to unistall and then reinstall your printer, every one in a while a printer driver update can cause an error in the system where the printer is listed as ready and printing but never buffers, so the fix is to unistall and reinstall it.
Jul 01, 2011 | Brother MFC 4420C All-In-One InkJet...
Scanner error 20 in hp laser jet m1319f
HP Printer Error Code 20 is a very common error on HP printers, which will show when your printer does not have the correct settings / configuration to enable it to be used properly. The error will generally show when you try and print a document on your HP printer, and will claim that the "Printer Is Not Activated". Although there are multiple causes of this specific error, the good news is that it is very easy to fix if you know what to do.
The error you're seeing will typically show like this:
•"Printer not activated - Error code 20′
The reason for HP Printer Error 20 to show is mainly down to the way in which Windows is continually trying to use the printer, and does not have the right settings / options for it. Printing a document with an HP Printer Error 20 is actually quite a feat, and your PC needs to have your printer set up in just the right way in order to achieve that.
Fortunately, there's a very simple and effective way to repair the Printer Error 20 in the most effective way possible - by using the steps outlined in this article.
The way to fix Printer Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. To make sure this problem is not an issue, you should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
After setting your HP Printer to be the default printing device for your system, you should then look to reinstall the printer on your PC to prevent Error 20.
You can do this by clicking onto "Device Manager" and then removing the printer from your system. On top of that, you should also look to remove any third party HP printer driver software from your PC, and install it again after a restart.
-Finally, you should also use a registry cleaner tool to fix the HP Printer Error 20. Registry cleaners are software tools which can fix any of the damaged settings and errors that your system might have inside. These tools are highly popular, and are used by 1,000's of people every day to help fix a variety of errors on your system. One of the biggest problems facing the HP Printer error 20 is the way in which many people's computers will actually have an incorrect file / setting inside the registry that's leading the error to show. To ensure this problem does not cause your system to become damaged, you should make sure that you can fix any registry errors Windows has.
Or the error may come like this :
Error code 20 Problem: "Not Enough Disk Space" error message
Possible Cause: Your computer needs free disk space to complete a print job. The amount of disk space required depends on the size of the file you're printing.
Solutions:
•A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
•On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
•On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
•Windows XP, click Start and then click Control Panel. Click Printers And Other Hardware and Printers And Faxes. In the Printers And Faxes window, from the File menu, click Server Properties, then click the Drivers tab. This shows the settings in your printer's driver. Compare the settings in this dialog box with the ideal settings in your printer's manual. If you see a discrepancy in these settings, the printer may simply need a new driver and delete old one. You can download printer drivers from the printer manufacturer's Web site.
• Get more help. Installing a new driver won't solve every printer woe, of course, so understanding printer's manual and Windows' built-in Help system will give you an even sharper troubleshooting edge.
Nov 09, 2010 | Office Equipment & Supplies
Error 52.00 Printer says cartridge installed. Looks all ready. Starts making a noice as if to print then stop within 1 second. Nothing shows on the print queue
52 error is a bad laser scanner. The scanner needs to be replaced. No other way to fix the problem. If you want an idea of cost call us at 262-993-1551.
Sep 02, 2010 | HP LaserJet 2300 Printer
My hp 4280 all in one wont print. it shows an
Rather than to analyze your problem and fixing, just uninstall all the softwares related to your printer from the control panel and reinstall them back using the driver cd came along with your printer and this should fix your problem. If still the problem persists, then try connecting and printing from any other PC/laptop to find out where exactly the problem is.
I hope this is helpful to you.
Thanks
Feb 07, 2010 | HP DeskJet F4280 All In One Printer InkJet
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
OKI C5510 MFP All-In-One Led Printer Logo
109 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
