Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have a 4000 watt onan generator it will crank but will not fire has oil fuel to it
  • 3,740 Answers
Are you sure there is fuel in the cylinder?
- If your sure that there is fuel in the cylinder then the next question is.....
*"Is there spark at the spark plug?" If no... suspect the low oil level sensor is dirty. You can remove it and clean it with carb cleaner then test it while NOT installed.
Open air... continutiy
submerged to threads in oil... +open / infinity reading.
This unit has a fuel pump and fuel filter. I don't remember if there is a fuel solenoid relay on the bottom of your carb or not. Older units do ot have them but newer ones do.
I really need to know Yes or no to these answers
Copy and past then delete the answer you do not want me to see. I.e. Y = del N or N= Del Yes
1. Fuel in cylinder Y / N
2. Oil sensor check good Y / N
3. Fuel pump running Y / N
4. Fuel solenoid installed Y / N
5. Spark at Spark Plug Y / N
6. Fuel Selector ON Y / N
I think we can do this but I really need to know the above answers.
Kelly
Posted on Sep 17, 2010
How to correct over crank fault??
Over crank is failure to start, check fuel and ignition, why it isnt starting
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
What is the oil filter for onan4000 generator
yes--- where is the oil filter on a onan 4000 in toy hauler?
Jul 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
491 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
